[GRASS-user] r.basin not running completely
jomaljochan
jochanjomal1998 at gmail.com
Fri Apr 24 23:49:45 PDT 2020
Hi, I am a new GRASS GIS User (using GRASS GIS 7.6.1) trying to get the
morphometric parameters of a watershed(Bhadra river basin, India).
Steps followed:
1) Cropped and set the DEM file in UTM projection.
2) Created a new location and used the georeferenced DEM file to set the
projection of GRASS Session.
3) Ran the following lines of code:
g.region rast=elevation at PERMANENT -ap
r.watershed -a elevation=elevation at PERMANENT accumulation=accum
r.stream.extract elevation=elevation at PERMANENT accumulation=accum
threshold=1000
stream_rast=stream_network stream_vect=streams --overwrite
#(overwrite with different threshold until clear network)
#Find the coordinates of the outlet from network and input in r.basin fn
r.basin map=elevation at PERMANENT prefix=out
coordinates=572957.585125,1547823.44718
threshold=20 dir=tmp/my_basin
The function stops running with the following error:
ERROR: option <output>: <tmp/my_basin\out_elevation_outlet_coors.txt>
exists. To overwrite, use the
--overwrite flag
An ERROR occurred running r.basin
Please check for error messages above or try with another pairs of outlet
coordinates
Removing region definition <original>
The details of the input DEM raster is:
| Map: elevation at PERMANENT Date: Sat Apr 25 11:48:17 2020
| Mapset: PERMANENT Login of Creator: Jomal Jochan
| DataBase: D:\STUDIES\sem8\Watershed Project\grassdata
| Title: elevation
| Timestamp: none
| Type of Map: raster Number of Categories: 0
| Data Type: CELL
| Rows: 1755
| Columns: 1785
| Total Cells: 3132675
| Projection: UTM (zone 43)
| N: 1548050.1657 S: 1495414.5575 Res: 29.99179954
| E: 605402.3491 W: 551850.8938 Res: 30.00081529
| Range of data: min = 552 max = 1737
| Data Description:
| generated by r.in.gdal
| Comments:
| r.in.gdal -e input="D:\STUDIES\sem8\Watershed Project\Bhadra_sample_\
| files\Input DEM\elevation.tif" output="elevation" memory=300 offset=\
| 0 num_digits=0
(Sat Apr 25 12:14:49 2020) Command finished (0 sec)
The output of the first line of code is given for your reference:
projection: 1 (UTM)
zone: 43
datum: wgs84
ellipsoid: wgs84
north: 1548050.1657
south: 1495414.5575
west: 551850.8938
east: 605402.3491
nsres: 29.99179954
ewres: 30.00081529
rows: 1755
cols: 1785
cells: 3132675
Any help is greatly appreciated! Thanks in advance!
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
