[GRASS-user] Sqlite error when calling GRASS GIS outside of GRASS
Helmut Kudrnovsky hellik at web.de
Fri Aug 7 05:31:50 PDT 2020
>I am getting this error:
>Process ended with non-zero return code 3221225785. See errors in the
(error)
it's a dll mixing/mismatch due to more of the same dll  in your %PATH%.
which library errored the message above? (sqlite? gdal?)
>g.run_command(r'C:\OSGeo4W64\apps\grass\grass78\bin\g.proj.exe',
georef=geotiff, location = >locationGeonet)
really an unusual way to invoke g.proj. never saw this working.
>I think this is a conflict with the sqlite3.dll as is suggested the below
wiki but the solutions there have >not worked for me.
>https://grasswiki.osgeo.org/wiki/WinGRASS_errors
which solutions did you try?
just open a normal windows console and type:
C:\Users\yourusername>where "$path:sqlite3*"
it's checking sqlite3 in your %PATH%
report back in your case.
when I open the OSGeo4W shell, I get
C:\>where "$path:sqlite3*"
C:\Program Files\QGIS 3.4\bin\sqlite3.dll
C:\Program Files\QGIS 3.4\bin\sqlite3.exe
is there a windows console availabe in the Spyder/ Anaconda framework? if
yes, then type where "$path:sqlite3*" and report back.
have you seen:
https://github.com/OSGeo/grass/issues/679
and the mentioned thread:
https://stackoverflow.com/questions/53682315/error-on-libcurl-dll-when-using-gdal-of-osgeo4w-in-django
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
