[GRASS-user] Import Shape Files
Markus Neteler
neteler at osgeo.org
Tue Aug 11 03:06:16 PDT 2020
Hi Martin,
(back to cc of list)
I just got a chance to test and also got the "invalid zone" message issue:
v.info LT_AOI_3
| Mapset: PERMANENT
| Database: /home/mneteler/grassdata
| Title:
| Map scale: 1:1
| Name of creator: mneteler
| Organization:
| Source date: Tue Aug 11 11:44:55 2020
| Timestamp (first layer): none
| Map format: native
| Type of map: vector (level: 2)
| Number of points: 5 Number of centroids: 0
| Projection: UTM (zone invalid)
This looks ok:
g.region vector=LT_AOI_3 -p
projection: 1 (UTM)
zone: -23
datum: sirgas2000
ellipsoid: grs80
north: 7397570.18085686
south: 7397525.93235069
west: 303308.13155207
east: 303364.49017572
nsres: 1.00564787
ewres: 1.00640399
rows: 44
cols: 56
cells: 2464
I checked the source code and it "simply" a bug in the printing logic in
v.info, as far as I see.
Means: all fine, just v.info gets confused with negative UTM zone values:
https://github.com/OSGeo/grass/blob/719725c22c9b2ceadbd009ae2f8acdeeef5a0fc9/vector/v.info/print.c#L497
I have opened an issue for this:
https://github.com/OSGeo/grass/issues/892
(with a GitHub account you can "subscribe" to it be remain informed.
You may simply ignore this "invalid zone" message for now.
Best,
Markus
On Tue, Jul 7, 2020 at 2:18 PM Martin Bittens <martin.bittens at gmx.de> wrote:
> Hello Markus,
> what is the edit button?
> Is that in GRASS?
> Sorry, that I have confused you a bit. Attached I am sending 2
> screenshots for a better explanation (GRASS_Edit_Button.jpg,
> GRASS_Edit_Metadata.jpg)
> Just to summarize our discussion:
> 1.) Creating a location/mapset by:
> # create new location from SHAPE file:
> grass78 -c LT_AOI_3.shp ~/grassdata/sirgas_2000
> Starting GRASS GIS...
> Creating new GRASS GIS location <sirgas_2000>...
> 2.) g.proj -w is showing beside other information the correct
> projection: "SIRGAS 2000 / UTM zone 23S"
> 3.) Import of LT_AOI_3.shp into the GRASS location/mapset which was
> created in 1.)
> 4.) Checking the metadata of the imported shape file by using (in GRASS):
> - the edit button (explanation see attached screenshots) results in:
> Projection UTM (zone invalid);
> - the v.info command results in: Projection UTM (zone invalid);
> - the v.info -w command results in: Projection UTM, zone -23.
> That's where we are now.
> Regards
> Martin
> Regards
> Martin
> Am 7/2/2020 um 5:53 PM schrieb Markus Neteler:
> > Hi Martin,
> > On Thu, Jul 2, 2020 at 10:03 PM Martin Bittens <martin.bittens at gmx.de>
> wrote:
> >> Hello Markus,
> >> that is exactly what I got (see one of my previous emails).
> > I read them several times but I am still lost:
> >> But...:-):
> >> If you import the shape-file you used for the setup of the
> >> location/mapset into this location/mapset and then check the metadata of
> >> the imported shape-file by
> >> -using the edit button;
> > Is that in GRASS?
> > Sorry, I am doing so many things in parallel, I need a bit of more
> detail.
> > Cheers
> > Markus
> >> -the v.info command;
> >> -the v.info -w command;
> >> what do you get?
> >> I get:
> >> -using the edit button: Projection UTM (zone invalid);
> >> -the v.info command: Projection UTM (zone invalid);
> >> -the v.info -w command: Projection UTM, zone -23
> >> That is what I did not figure out, why GRASS provides different meta
> >> data for the same shape-file although the location/mapset meta did not
> >> change and remains "SIRGAS 2000 / UTM zone 23S".
> >> Regards
> >> Martin
> >> Am 7/2/2020 um 3:26 PM schrieb Markus Neteler:
> >>> Hi Martin,
> >>> On Thu, Jul 2, 2020 at 1:57 PM Martin Bittens <martin.bittens at gmx.de>
> wrote:
> >>>> Hello Markus,
> >>>> ok, let us try.
> >>>> Attached I send (as zip files):
> >>>> 1.) QGIS_LT_AOI_3.zip with a shape layer created in QGIS 2.14.0. It
> >>>> contains contains 5 sample points extracted from an existing site
> (EPSG
> >>>> 31983);
> >>>> 2.) Test_SG.zip with the files from the grassdata directory created by
> >>>> GRASS 7.8.3 after establishing the location "Test_SG" (EPSG 31983) and
> >>>> importing the shape layer into "Test_SG".
> >>> I tried and got this:
> >>> Welcome to GRASS GIS 7.8.4dev (0798df3d0)
> >>> GRASS 7.8.4dev (sirgas_2000):/tmp > g.proj -w
> >>> PROJCS["SIRGAS 2000 / UTM zone 23S",
> >>> GEOGCS["SIRGAS 2000",
> DATUM["Sistema_de_Referencia_Geocentrico_para_las_AmericaS_2000",
> >>> SPHEROID["GRS 1980",6378137,298.257222101,
> >>> AUTHORITY["EPSG","7019"]],
> >>> TOWGS84[0,0,0,0,0,0,0],
> >>> AUTHORITY["EPSG","6674"]],
> >>> PRIMEM["Greenwich",0,
> >>> AUTHORITY["EPSG","8901"]],
> >>> UNIT["degree",0.0174532925199433,
> >>> AUTHORITY["EPSG","9122"]],
> >>> AUTHORITY["EPSG","4674"]],
> >>> PROJECTION["Transverse_Mercator"],
> >>> PARAMETER["latitude_of_origin",0],
> >>> PARAMETER["central_meridian",-45],
> >>> PARAMETER["scale_factor",0.9996],
> >>> PARAMETER["false_easting",500000],
> >>> PARAMETER["false_northing",10000000],
> >>> UNIT["metre",1,
> >>> AUTHORITY["EPSG","9001"]],
> >>> AXIS["Easting",EAST],
> >>> AXIS["Northing",NORTH],
> >>> AUTHORITY["EPSG","31983"]]
> >>> To me it looks as expected.
> >>> My software versions:
> >>> g.version -rge
> >>> version=7.8.4dev
> >>> date=2020
> >>> revision=0798df3d0
> >>> build_date=2020-07-02
> >>> build_platform=x86_64-pc-linux-gnu
> >>> build_off_t_size=8
> >>> libgis_revision=8e4dab571
> >>> libgis_date=2020-05-05T09:05:27+00:00
> >>> proj=6.3.2
> >>> gdal=3.0.4
> >>> geos=3.8.1
> >>> sqlite=3.32.2
> >>> Might it be that your PROJ installation is somehow broken?
> >>> best,
> >>> Markus
> >> This email has been checked for viruses by Avast antivirus software.
> >> https://www.avast.com/antivirus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200811/09268787/attachment-0001.html>
