[GRASS-user] unstable results with r.param.scale ?
    Vincent Godard
    godard at cerege.fr
    Wed Dec  9 04:59:42 PST 2020
Dear Grass users,
I've been using r.param.scale to compute various type of curvatures over
a 1 m LiDAR DEM (FCELL) (from opentopography.org) :
r.param.scale --o -c input=dem output=curvature size=15 method=profc
r.info -r curvature
I usually get reasonable results like (checked with independent
calculations) :
min=-0.203124601340989
max=0.0685868278408049
But when running this command repeatedly, I randomly (usually every 3rd
or 4th time) get very different results like :
min=-127112309.998249
max=131128979.492382
I am running GRASS 7.8.4 on Ubuntu 20.04. The problem is also present
when running r.param.scale from QGIS or rgrass7 (in a R session).
I have replicated the problem with another high resolution DEM of
different source (still FCELL), and also with a 30 m SRTM DEM (CELL),
but in this case the occurrence of these odd results is less frequent
and they are not contrasting as much with the expected outcome ("only"
by a 1 or 2 order of magnitude). The problem is present with or without
the -c option, and seems only to affect the computation of curvatures
(profc,planc,longc,crosc,minic,maxic).
Has anyone encountered something like that, or have any idea about what
might be going on?
Thanks in advance,
Vincent
Vincent Godard
CEREGE, OSU Pythéas
Aix-Marseille Université
Europôle Méditerranéen de l’Arbois - BP 80
13545 Aix-en-Provence cedex 04, France
godard at cerege.fr
