[GRASS-user] More Fun Compiling & Installing GRASS on CentOS 8
mdwxman mdwxman at protonmail.com
Fri Dec 18 13:03:06 PST 2020
Thank you Markus.  I suspected something like this.  The version(s) of GDAL now on my computer are of the 2.4... variety.  After reading through your bugzilla messages from 2018 ff. I suspected there was more to the story.
Thank you.
Michael Allen
Industrial Weather
763-777-1263
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Friday, December 18, 2020 2:47 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Fri, Dec 18, 2020 at 5:19 AM mdwxman via grass-user
> grass-user at lists.osgeo.org wrote:
> > Looks like more fun here at dog fur manor. I'm still stuck on the compilation of grass-7.8.5RC1 on CentOS 8.
> > The script stops at line 6788 in the configure script with the ERROR message: Cannot find grass-config.
> This is unexpected. Do you mean
> gdal-config
> If yes, you need to install the "gdal-devel" RPM.
> In general, also other development packages like "proj-devel" are
> needed. The list is in the Wiki page cited below.
> > I've moved grass-config to many different subdirectories but always with the same result.
> > I used the methods on https://grasswiki.osgeo.org/wiki/Compile_and_Install#CentOS
> > under the CentOS 8 and the GRASS 7 instructions. The installation of all dependencies went fine but apparently there is an issue with grass-config.
> Please use to "gdal-config" as per Wiki page.
> Markus
