[GRASS-user] Add-Ons and batch job with the --exec interface
Vincent Bain
bain at toraval.fr
Sun Dec 20 03:21:20 PST 2020
Thank you Micha for your hint.
Not sure I catch the difference between both directories. Should I
consider GRASS_ADDON_BASE a place I can store my "user" addons, and
GRASS_ADDON_PATH the "system" one?
Yours,
V
Le dimanche 20 décembre 2020 à 13:17 +0200, Micha Silver a écrit :
> On 12/20/20 1:01 PM, Vincent Bain wrote:
> > Hi dear Grass users,
> > I'm wondering how/if one can run an Add-On command while invoking
> > grass
> > from the --exec interface.
> > As an example, if I run :
> > grass79 /path/to/my/location/mapset --exec g.list rast
> > I succeed.
> > As well as checking my GRASS_ADDON_PATH :
> Maybe it should be GRASS_ADDON_BASE.
> micha at RMS:~$ env | grep ADDON
> GRASS_ADDON_BASE=/home/micha/.grass7/addons/
> Now before initializing GRASS:
> micha at RMS:~$ export GRASS_ADDON_BASE=/home/micha/.grass7/addons/
> micha at RMS:~$ grass /home/micha/GIS/grass/ITM/Arava/ --exec
> r.stream.order
> Starting GRASS GIS...
> Cleaning up temporary files...
> Executing <r.stream.order> ...
> Calculates Strahler's and more streams hierarchy.
> Usage:
> r.stream.order [-zma] stream_rast=name direction=name
> [elevation=name]
> [accumulation=name] [stream_vect=name] [strahler=name]
> [horton=name]
> [shreve=name] [hack=name] [topo=name] [memory=value] [
> --overwrite]
> [--help] [--verbose] [--quiet] [--ui]
> Flags:
> -z Create zero-valued background instead of NULL
> -m Use memory swap (operation is slow)
> -a Use flow accumulation to trace horton and hack models
> Parameters:
> stream_rast Name of input raster map with stream network
> direction Name of input flow direction raster map
> elevation Name of input elevation raster map
> accumulation Name of input accumulation raster map
> stream_vect Name for output vector map to write stream
> attributes
> strahler Name for output Strahler's stream order raster map
> horton Name for output original Hortons's stream order
> raster map
> shreve Name for output Shereve's stream magnitude raster
> map
> hack Name for output Hack's streams or Gravelius stream
> hierarchy raster map
> topo Name for output topological dimension of streams
> raster map
> memory Max memory used in memory swap mode (MB)
> default: 300
> Execution of <r.stream.order> finished.
> Cleaning up default sqlite database ...
> > echo $GRASS_ADDON_PATH
> > /usr/local/grass-addons/
> > But :
> > grass79 /path/to/my/location/mapset --exec r.my.addon
> > fails :
> > [Errno 2] No such file or directory: 'r.my.addon': 'r.my.addon'
> > Exiting...
> > Would anyone help me solve this issue ?
> > Have a nice sunday,
> > Vincent.
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
