[GRASS-user] Umm...OK, How do I start this thing?
mdwxman mdwxman at protonmail.com
Sat Dec 26 23:45:57 PST 2020
After all these years you would think that I would have automatically run “make install” or that I would have read the directions. Nope, not this time. Thanks for laying out the path comment. I’ll try to avoid being so neglectful in the future...
Michael Allen
Industrial Weather
763-777-1263
On Sun, Dec 27, 2020 at 1:38 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Michael,
> mdwxman via grass-user <grass-user at lists.osgeo.org> schrieb am So.,
> 27. Dez. 2020, 06:19:
>> I must be either blind or brain-frozen by all the snow outside but even after reading through the introductions
>> and downloading the North Carolina data I still don't see how to start GRASS GIS 7.8.5 on my Fedora 33.
> The reason will be that the start script isn't yet in $PATH.
> So, the question is: did you run this step
> sudo make install
> - if yes, then it should be in /usr/local/bin/ which needs to be in
> $PATH (usually it is)
> - if no, then you need to create a link:
> ln -s /where/you/compiled/grass_src/bin.x86_64-pc-linux-gnu/grass78
> /some/directory/in/path/
> Example (here in detail, also for others being interested):
> So, in my $HOME I always create a "$HOME/bin/" directory into which I
> then link the GRASS GIS startup script (and also other unrelated
> stuff). Hence:
> mkdir $HOME/bin/
> Then add this line into $HOME/.bashrc (assuming that you use bash shell):
> export PATH=$PATH:$HOME/bin
> Next create the link (adapt path as needed):
> ln -s $HOME/where/you/compiled/grass_src/bin.x86_64-pc-linux-gnu/grass78
> $HOME/bin/
> Now either start a new terminal or execute one time (needed as the
> current terminal only reads $HOME/.bashrc at startup):
> Now you should be able to start
> grass78
>> I have over 30 years experience with Unix or Linux and I still don't see a startup file. What am I missing?
> It is all about having the start scipt in $PATH.
> HTH,
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201227/556cfbb5/attachment.html>
