[GRASS-user] Umm...OK, How do I start this thing?
mdwxman
mdwxman at protonmail.com
Sun Dec 27 21:12:26 PST 2020
Very strange things happening here and I don't understand.
1. I ran make install in the src directory and it finished without error. grass78 is in /usr/local/bin as it should be. But running grass78 from this directory produces this output:
(base) [root at godelsrevenge ~]# /usr/local/bin/grass78 --gui
Starting GRASS GIS...
ERROR: wxGUI requires wxPython. No module named 'wx'
You can still use GRASS GIS modules in the command line or in Python.
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
grass78 --help
See also: https://grass.osgeo.org/grass78/manuals/helptext.html
Exiting...
Checking for wxPython produces this:
(base) [root at godelsrevenge ~]# find / -name wxPython
find: File system loop detected; ‘/run/media/root/fedora_fedora5/root’ is part of the same file system loop as ‘/’.
find: File system loop detected; ‘/run/media/root/fedora_fedora4/root’ is part of the same file system loop as ‘/’.
find: File system loop detected; ‘/run/media/root/fedora_fedora3/root’ is part of the same file system loop as ‘/’.
find: File system loop detected; ‘/run/media/root/fedora_fedora2/root’ is part of the same file system loop as ‘/’.
find: File system loop detected; ‘/run/media/root/fedora_fedora1/root’ is part of the same file system loop as ‘/’.
find: File system loop detected; ‘/run/media/root/fedora_fedora/root’ is part of the same file system loop as ‘/’.
/usr/lib64/python3.9/site-packages/wx/include/wxPython
The source file for grass-7.8.5 is at : /grass-7.8.5 NOT /root/grass-7.8.5.
Next I checked echo $PATH and received this message:
(base) [root at godelsrevenge ~]# echo $PATH
/usr/lib64/python3.9/site-packages/wx/include:/root/anaconda3/bin:/root/anaconda3/condabin:/usr/lib64/python3.9/site-packages/wx/include:/usr/lib64/ccache:/usr/local/sbin:/usr/sbin:/usr/local/bin:/usr/bin:/bin
but here's my .bashrc file:
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
# User specific environment
# Uncomment the following line if you don't like systemctl's auto-paging feature:
# export SYSTEMD_PAGER=
# User specific aliases and functions
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
# >>> Export for wxPython >>>
export PATH="/usr/lib64/python3.9/site-packages/wx/include:$PATH"
# >>> conda initialize >>>
# !! Contents within this block are managed by 'conda init' !!
__conda_setup="$('/root/anaconda3/bin/conda' 'shell.bash' 'hook' 2> /dev/null)"
if [ $? -eq 0 ]; then
eval "$__conda_setup"
else
if [ -f "/root/anaconda3/etc/profile.d/conda.sh" ]; then
. "/root/anaconda3/etc/profile.d/conda.sh"
else
export PATH="/root/anaconda3/bin:$PATH"
fi
fi
unset __conda_setup
# <<< conda initialize <<<
So what is the origin of that long line of PATH directories when they don't appear in the .bashrc file? (I checked to make sure I was running bash).
And if /usr/local/bin contains grass78 and wxPython is located in /usr/lib64/python3.9/site-packages/wx/includes then why is grass78 missing the wxPython file?
And I also checked using find / -name grass-gui and came up with nothing, that is grass-gui is missing.
I hope I've included enough detail to help with this.
Michael Allen
Industrial Weather
763-777-1263
Sent with ProtonMail Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Sunday, December 27, 2020 8:00 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Sun, 27 Dec 2020, mdwxman wrote:
> > And that's a very good idea! I just went through the process of creating a(base) [root at godelsrevenge ~]# find / -name wxPython
> > link to the GRASS78 file. Your idea is something I never considered. I
> > guess too many years of managing Unix and Linux systems with command lines
> > has stopped the creative juices from using the GUIs that were put there
> > for everyone's benefit!
> Mike,
> Your method of invoking grass should reflect how you want to work with it.
> I've been using grass since version 4.0 (integer numbers only) and most of
> the time work strictly from the command line. Now and then I want to use the
> GUI so I'll start it that way ... from the command line.
> You can select how it starts by, for example, $ grass79 -text or $ grass73
> -gui (I beta test the development builds by using them when I do spatial
> analyses.
> The list of command line startup options is on a document page. I don't know
> which one now that the web site's been restructured.
> Stay well,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
</rshepard at appl-ecosys.com>
