[GRASS-user] Polar projection
Jón Eiríksson jeir at hi.is
Thu Dec 31 09:23:19 PST 2020
This has worked for me:
(Thu Dec 31 17:22:11 2020)
g.proj -p
-PROJ_INFO-------------------------------------------------
proj       : stere
datum      : wgs84
ellps      : wgs84
lat_0      : 90
lat_ts     : 70
lon_0      : -45
k          : 1
x_0        : 0
y_0        : 0
no_defs    : defined
towgs84    : 0.000,0.000,0.000
-PROJ_EPSG-------------------------------------------------
epsg       : 3413
-PROJ_UNITS------------------------------------------------
unit       : meter
units      : meters
meters     : 1
(Thu Dec 31 17:22:11 2020) Command finished (0 sec)
Jon
On 31 Dec 2020, at 16:26, Markus Neteler wrote:
> Hi Ken,
> On Thu, Dec 31, 2020 at 3:06 AM Ken Mankoff <mankoff at gmail.com> wrote:
>> Dear GRASS List,
>> Can someone suggest what setup to use (EPSG code? proj4 code?) to
>> have the projection centered on the N. pole? I'm looking to create a
>> graphic similar to this image in the Raster Gallery:
>> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgrass.osgeo.org%2F%2Fimages%2Fgallery%2Fraster%2Fday_on_earth_N.png&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118244590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=1b0EG%2B%2ByT0LjNGOp55l%2FwYiVKSNfAeUvd%2BZS12dCWZg%3D&reserved=0
>> If I set up a polar projection based on
>> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fspatialreference.org%2Fref%2Fsr-org%2F8243%2F&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118244590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=I7u9KAIJ0geqmtTPZv1vUg3kiAtqtASajvhxzCwFmy4%3D&reserved=0
>> using:
>> grass -c ./G
>> g.proj -c proj4="+proj=stere +lat_0=90 +lat_ts=45 +lon_0=-170 +k=1
>> +x_0=0 +y_0=0 +ellps=WGS84 +datum=WGS84 +units=m +no_defs"
>> Things mostly work, but
>> d.grid -g 1:0 color=red
>> does not show latitude lines on most of the graphic (see attached).
> I managed to generate it with
> Preparation of a 10 degree grid:
> # EPSG:4326
> GRASS :~ > g.region -dp
> projection: 3 (Latitude-Longitude)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      90N
> south:      90S
> west:       180W
> east:       180E
> nsres:      1
> ewres:      1
> rows:       180
> cols:       360
> cells:      64800
> GRASS :~ > v.mkgrid grid=36,18 map=grid_10deg
> # download "Natural Earth I with Shaded Relief, Water, and Drainages"
> from
> https://eur02.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.naturalearthdata.com%2Fdownloads%2F10m-raster-data%2F10m-natural-earth-1%2F&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118244590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=at%2BPzc3vGV%2FmxVhg%2BxltDODIC52rrl%2Bd39ZTtta7uDA%3D&reserved=0
> GRASS :~ > r.import in=NE1_HR_LC_SR_W_DR.tif
> output=natural_earth_global_landcover
> GRASS :~ > g.region raster=natural_earth_global_landcover.1
> GRASS :~ > r.composite r=natural_earth_global_landcover.1
> g=natural_earth_global_landcover.2 b=natural_earth_global_landcover.3
> out=natural_earth_global_landcover.rgb
> GRASS :~ > exit
> # WGS 84 / Arctic Polar Stereographic
> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fepsg.io%2F3995&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118244590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=JwnkjczUnnrbi%2F%2BnQGepiYo4eB02S5%2BQUWSMK3rRFDs%3D&reserved=0
> grass78 -c epsg:3995 ~/grassdata/arctic_polar_stereographic
> GRASS :~ > g.proj -w
> PROJCS["WGS 84 / Arctic Polar Stereographic",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.0174532925199433,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Polar_Stereographic"],
>     PARAMETER["latitude_of_origin",71],
>     PARAMETER["central_meridian",0],
>     PARAMETER["false_easting",0],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AXIS["Easting",SOUTH],
>     AXIS["Northing",SOUTH],
>     AUTHORITY["EPSG","3995"]]
> GRASS :~ > g.region n=2930000 s=-2500000 w=-4250000 e=4310000
> nsres=10000 ewres=10000 -p
> GRASS :~ > v.proj location=latlong_wgs84 mapset=PERMANENT
> input=grid_10deg
> GRASS :~ > r.proj location=latlong_wgs84 mapset=PERMANENT
> input=natural_earth_global_landcover.rgb
> GRASS :~ > d.mon wx0
> GRASS :~ > d.rast natural_earth_global_landcover.rgb
> GRASS :~ > d.vect grid_10deg type=boundary
> The resulting map looks as attached (hope I didn't forget to copy a
> command here).
> Indeed, d.grid doesn't looks as expected
> GRASS :~ > d.grid 10 -w
> .. is incomplete. Worth a bug report, IMO.
> Cheers,
> Markus
> Markus Neteler, PhD
> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.mundialis.de%2F&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118244590%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=R0%2BkMUwS4HSEjqNltZIopTVnEv7c%2FUSCfKjrHT%2BWOIE%3D&reserved=0
> - free data with free software
> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgrass.osgeo.org%2F&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118254587%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=7zy0UjA7NFrLeIDwhmkpoHJQrGn05abGojvoPEpDXOw%3D&reserved=0
> https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fcourses.neteler.org%2Fblog&data=04%7C01%7Cjeir%40hi.is%7Cc4ce599d0faf40d3408608d8ada8dff2%7C09fa5f0e211846568529677ed8fdbe78%7C0%7C0%7C637450288118254587%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=JB5zKZRxku4818pqUJirSvMG3lyrA%2Bx50LLUBzVxkyU%3D&reserved=0
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
