[GRASS-user] ESRI formats: gdb and shp
    Daniel Victoria
    daniel.victoria at gmail.com
    Tue Feb 11 10:39:59 PST 2020
Rich,
This is an old PDF (2009) but it lists some advantages of file geodatabase.
https://www.esri.com/news/arcuser/0309/files/9reasons.pdf
Another thing worth mentioning is that in order to do topological analysis
in ESRIs world, you would need to use geodatabases since shapefiles does
not carry topology information.
But you mentioned that you are dealing with point data. I never heard of
using topology with point data. So you are probably fine importing from
either one (shape or gdb)
Also, don't know it the topology part of a GDB file is recognized by
OGR/grass. I believe Grass generates the topology once it's imports vector
data, be it from shapefile or GDB.
Now, if the attribute table has long column names, accents and things like
that, it's probably correct in the GDB. Remember that shapefiles use DBF
for attribute table...
Disclaimer: I haven“t used an ESRI product in a long time. So the
information in here could be outdated
Cheers
Daniel
On Tue, Feb 11, 2020 at 1:56 PM Rich Shepard <rshepard at appl-ecosys.com>
wrote:
> On Tue, 11 Feb 2020, Daniel Victoria wrote:
> > What do you mean by better? Correct data? Easier to import?
> Daniel,
> More complete topographic information. I recall learning a long time ago
> that shapefiles are not as topographically complete as other formats such
> as
> the older (and excellent) .e00 files. Do gdb files have any additional
> information compared with shp files? Are they preferred for some reason?
> Thanks,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200211/15ed0122/attachment.html>
