[GRASS-user] Importing Point-Cloud with v.in.lidar
Olivier.C.Canon at umwelt.uni-giessen.de
Wed Feb 12 08:50:48 PST 2020
Hello,
just Need to add a realisation: Maybe the problem is the space in the
direction. I already tried loading the input file from direction
without space, but it didn’t solve the problem. So I thought it must
be something else.
But now I learned that Gis has in general problems with spaces in
filenames, so I will first try undo the connection with the Cloud, to
evoid the spaces in all directories.
I thought to safe my data this way would be a good idea, but seems not
to be the best solution…
Zitat von Olivier.C.Canon at umwelt.uni-giessen.de:
> Hello grass-community,
> Actually I’m working for a research project (master thesis) with
> point data, that were exported from dronedeploy one year ago.
> Unfortunately processing the exported LAS-files is quit challenging,
> as there are some issues with the file format (e.g. the projection).
> My aim is to import the data into Grass-GIS to process it there with
> the 3D-fragmentation tool. But till now I was not able to import it…
> So I thought I’ll ask for some help here.
> I tried to process the data with several tools, like lidR package in
> R-Studio and LAStools. First I had to change the projection with
> las2las to a appropriate (EPSG 3116) one, to be able to display it
> correctly in these tools. Now I can do further processing with the
> data, like creating grids. By the way, these grids are located
> correctly when loading them to a GIS-application. So coordinates
> seem to be correctly. Anyway loading the point-data to Grass-GIS
> (with v.in.lidar tool) fails, because the points are in a wrong
> location/projection. I did not use -r (limit to current region), so
> this can not be the problem. First it did calculate something and
> added a vector map that seemed to be empty, because there was
> nothing displayed.
> Actually it doesn’t even start calculating and there is no vector
> map produced. I copied the output below. I already got the hint to
> try importing a ASCII text by converting the LAS file with PDAL. So
> I will try installing PDAL on my PC. Anyway, maybe some has a
> solution for the v.in.lidar problem.
> Output:
> QGIS version: 3.10.2-A Coruña
> QGIS code revision: d4cd3cfe5a
> Qt version: 5.11.2
> GDAL version: 3.0.4
> GEOS version: 3.8.0-CAPI-1.13.1
> PROJ version: Rel. 6.3.0, January 1st, 2020
> Processing algorithm…
> Algorithm 'v.in.lidar' starting…
> Input parameters:
> { '-b' : False, '-c' : False, '-t' : False,
> 'GRASS_OUTPUT_TYPE_PARAMETER' : 0, 'GRASS_REGION_PARAMETER' :
> '1209933.8649246846,1210526.7738715957,820900.5310786865,821470.5180333158
> [EPSG:3116]', 'GRASS_VECTOR_DSCO' : '', 'GRASS_VECTOR_EXPORT_NOCAT'
> : True, 'GRASS_VECTOR_LCO' : '', 'class_filter' : '', 'input' :
> 'C:\\Users\\oc\\OneDrive - HH
> Gruppe\\Dokumente\\Uni\\Master\\Daten\\Daten_Stuktur\\points\\110_1.las',
> 'limit' : None, 'offset' : None, 'output' : 'TEMPORARY_OUTPUT',
> 'preserve' : None, 'return_filter' : [], 'skip' : None, 'spatial' :
> None, 'zrange' : [nan,nan] }
> g.proj -c proj4="+proj=tmerc +lat_0=4.59620041666667
> +lon_0=-74.0775079166667 +k=1 +x_0=1000000 +y_0=1000000 +ellps=GRS80
> +towgs84=0,0,0,0,0,0,0 +units=m +no_defs"
> g.region n=821470.5180333158 s=820900.5310786865
> e=1210526.7738715957 w=1209933.8649246846
> v.in.lidar -o input="C:\Users\oc\OneDrive - HH
> Gruppe\Dokumente\Uni\Master\Daten\Daten_Stuktur\points\110_1.las"
> output=output2221d86f3dd44a7c84ead4bac980f243 --overwrite
> v.out.ogr type="auto" input="output2221d86f3dd44a7c84ead4bac980f243"
> output="C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\cc8523d5d751483b9922084e16845571\output.gpkg" format="GPKG" -c
> --overwrite
> Starting GRASS GIS...
> WARNING: Concurrent mapset locking is not supported on Windows
> Cleaning up temporary files...
> Executing
> <C:\Users\oc\AppData\Local\Temp\processing_073544cf878b4dd8b5311a6a5d27abcc\grassdata\grass_batch_job.cmd>
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>chcp 1252 1>NUL
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>g.proj -c
> proj4="+proj=tmerc +lat_0=4.59620041666667 +lon_0=-74.0775079166667
> +k=1 +x_0=1000000 +y_0=1000000 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0
> +units=m +no_defs"
> Default region was updated to the new projection, but if you have
> multiple mapsets `g.region -d` should be run in each to update the
> region from the default
> Projection information updated
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>g.region
> n=821470.5180333158 s=820900.5310786865 e=1210526.7738715957
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>v.in.lidar -o
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>v.out.ogr type="auto"
> --overwrite
> ERROR: Vector map <output2221d86f3dd44a7c84ead4bac980f243> not found
> C:\Users\oc\OneDrive - HH Gruppe\Dokumente>exit
> Execution of
> finished.
> Drücken Sie eine beliebige Taste . . .
> Execution completed in 13.86 seconds
> Results:
> {'output': <QgsProcessingOutputLayerDefinition
> {'sink':TEMPORARY_OUTPUT, 'createOptions': {'fileEncoding':
> 'System'}}>}
> Loading resulting layers
> The following layers were not correctly
> generated.<ul><li>C:\Users\oc\AppData\Local\Temp/processing_073544cf878b4dd8b5311a6a5d27abcc/cc8523d5d751483b9922084e16845571/output.gpkg</li></ul>You can check the 'Log Messages Panel' in QGIS main window to find more information about the execution of the
> algorithm.
> Kind regards, Olivier Canon
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
