[GRASS-user] r.proj ERROR
Nikolai Hafner
n.hafner at carto.at
Mon Jan 13 06:01:28 PST 2020
Am 13.01.2020 um 14:23 schrieb Markus Metz:
> Nik, have you set the current region correctly?
> > for r.proj -g you don't need the pipeline, try just
> > r.proj -g location=MGI2wgs84_Austria_Lambert mapset=PERMANENT
> > input=dhm_10m_ogd_austria
> > see also example https://grass.osgeo.org/grass78/manuals/r.proj.html
> > # same calculation, but in a form which can be cut and pasted into a
> > g.region call
> > r.proj input=elevation location=ll_wgs84 mapset=user1 -g
> > the pipeline is needed later for the reprojection process.
> A pipeline is not really needed, in case of several possible
> operations, PROJ should automagically select the best available
> operation. Note that also with r.proj -g coordinate transformation
> takes place.
thx Markus and Helmut!
Yes that is what I would expect and what I´ve done many times before but
since shortly I get this message:
r.proj location=MGI2wgs84_Austria_Lambert mapset=PERMANENT
input=dhm_10m_ogd_austria output=dhm_10m_ogd_dachstein_NEU method=bilinear
resolution=10
ERROR: Unable to open element file <> for <WIND at dachstein>
I tested it from an other location too but it´s the same problem:
r.proj location=ASTER_lat-long mapset=PERMANENT
input=DHM_SRTM30m_Aut-plus-Umgebung output=dhm_30m_ASTER_dachstein
method=bilinear resolution=30
What does that mean?
the pojection and region settings of both input and output are als follows:
g.proj -p
-PROJ_INFO-------------------------------------------------
name : Lambert Conformal Conic
proj : lcc
datum : hermannskogel
ellps : bessel
lat_1 : 49
lat_2 : 46
lat_0 : 47.5
lon_0 : 13.33333333333333
x_0 : 400000
y_0 : 400000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_UNITS------------------------------------------------
unit : metre
units : metres
meters : 1
g.region -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: hermannskogel
ellipsoid: bessel
north: 576922.51207363
south: 273692.51207363
west: 106549.26720377
east: 694629.26720377
nsres: 10
ewres: 10
rows: 30323
cols: 58808
cells: 1783234984
g.proj -p
name : Universal Transverse Mercator
proj : utm
datum : etrs89
ellps : grs80
zone : 33
towgs84 : 0,0,0,0,0,0,0
no_defs : defined
unit : metre
units : metres
meters : 1
g.region -p
projection: 1 (UTM)
zone: 33
datum: etrs89
ellipsoid: grs80
north: 5286581.58847414
south: 5248335.67358037
west: 380870.53610518
east: 429633.13185005
nsres: 9.998932
ewres: 10.00053235
rows: 3825
cols: 4876
cells: 18650700
