[GRASS-user] Running r.topix hangs up
Huidae Cho
grass4u at gmail.com
Mon Jan 27 18:52:09 PST 2020
Hi Valter,
It would also help if you could share your data. I can take a look into the
r.topidx code to see what's happening.
Best,
Huidae
On Sun, Jan 26, 2020 at 3:47 PM Markus Metz <markus.metz.giswork at gmail.com>
wrote:
> On Sun, Jan 26, 2020 at 9:13 PM Valter Albino <valteralbino at gmail.com>
> wrote:
> > Hi,
> > Looking to produce a TWI. When running "r.topix", this hangs up at 74%.
> What should be the problem?
> Does r.topix crash, if yes, what it the error message, or does it just
> take a long time to proceed after 74% have been reached?
> The following information will also help to solve the problem:
> What is the size of the input file in terms of rows and columns, what is
> the current region, which operating system and how much free RAM on this
> operating system?
> Alternatively, you can also use the tci output of r.watershed.
> Markus M
> > (Using 7.8.1.dev or 7.6.1 or from GRASS modules in QGIS)
> > Cumprimentos,
> > Valter Albino - Geógrafo Físico, M.Sc.
> > Modelação H&H / Riscos ambientais / OT&U
> > www.valteralbino.wixsite.com/hydrodynamics
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/grass-user
Huidae Cho, Ph.D., GISP
GRASS GIS Developer
https://idea.isnew.info
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200127/d679c5a3/attachment.html>
