[GRASS-user] Flow line [r.flow]
Huidae Cho
grass4u at gmail.com
Mon Jan 27 18:56:02 PST 2020
Valter,
Which module did you use to generate flow lines? It wouldn't be easy to
troubleshoot your problem without sample data and detail steps. Are those
purple and black lines flow lines?
Best,
Huidae
On Wed, Jan 15, 2020 at 3:58 PM Valter Albino <valteralbino at gmail.com>
wrote:
> Is it normal results, scattered flow lines in a landscape with altimetric
> amplitude of 50 to 60 meters (see following image). Is it an erratic result?
> [image: imagem.gif]
> Cumprimentos,
> *Valter Albino -* Geógrafo Físico, M.Sc.
> Modelação H&H / Riscos ambientais / OT&U
> www.valteralbino.wixsite.com/hydrodynamics
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Huidae Cho, Ph.D., GISP
GRASS GIS Developer
https://idea.isnew.info
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200127/bcbd4238/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200127/bcbd4238/attachment-0001.gif>
