[GRASS-user] error in i.sentinel.mask: nan values in xml file
Veronica Andreo
veroandreo at gmail.com
Wed Jan 29 05:53:00 PST 2020
Hi Robi,
My bad, region was wrong... anyway, trying to replicate from the beginning
I see that i.sentinel.import with -r is importing empty maps. However, the
jp2 files have data. I can visualize them in QGIS. I'll report in a
different thread. Once I can figure it out and reach this point again, I'll
report back to you. Thanks for the clarification!
Cheers
Vero
El mié., 29 ene. 2020 a las 9:08, roberta fagandini (<
robifagandini at hotmail.it>) escribió:
> Hi Vero,
> i.sentinel.mask doesn't retrieve the maximum from the xml file but
> computes the value from the image using r.univar. The error could be due to
> the computational region..has the region been set correctly?
> Can you send the MTD_TL.xml file? I can download the image and make some
> tests.
> Roberta
> *Da:* grass-user <grass-user-bounces at lists.osgeo.org> per conto di
> Veronica Andreo <veroandreo at gmail.com>
> *Inviato:* martedì 28 gennaio 2020 19:57
> *A:* grass-user <grass-user at lists.osgeo.org>
> *Oggetto:* [GRASS-user] error in i.sentinel.mask: nan values in xml file
> Hello
> I try to use i.sentinel.mask but I get the following error:
> i.sentinel.mask blue=$blue green=$green red=$red swir11=$swir11 nir=$nir
> swir12=$swir12 nir8a=$nir8a cloud_mask=cloud shadow_mask=shadow
> mtd_file=`find $out_dir -name 'MTD_TL.xml'`
> ADVERTENCIA: All subsequent operations will be limited to the current
> ADVERTENCIA: Any rescale factor has been applied
> --- Start computing maximum values of bands ---
> T21JYM_20200126T134201_B02_10m
> T21JYM_20200126T134201_B03_10m
> T21JYM_20200126T134201_B04_10m
> T21JYM_20200126T134201_B08_10m
> T21JYM_20200126T134201_B8A_20m
> T21JYM_20200126T134201_B11_20m
> T21JYM_20200126T134201_B12_20m
> --- Computed maximum value: dict_values([nan, nan, nan, nan, nan, nan,
> nan]) ---
> --- Statistics have been computed! ---
> --- Start clouds detection procedure ---
> --- Computing cloud mask... ---
> Mapa no válido <nan>
> Parse error
> ERROR: error al parsear
> ERROR: An error occurred while running r.mapcalc with expression:
> cloud_def82115 = if((((T21JYM_20200126T134201_B02_10m > (0.08*nan))
> && (T21JYM_20200126T134201_B03_10m > (0.08*nan)) &&
> (T21JYM_20200126T134201_B04_10m > (0.08*nan))) == 1) &&
> (((T21JYM_20200126T134201_B04_10m < ((0.08*nan)*1.5)) &&
> T21JYM_20200126T134201_B12_20m*1.3)) == 0) &&
> (((T21JYM_20200126T134201_B11_20m < (0.1*nan)) &&
> (T21JYM_20200126T134201_B12_20m < (0.1*nan))) == 0) &&
> ((if(T21JYM_20200126T134201_B8A_20m ==
> max(T21JYM_20200126T134201_B8A_20m, 2 *
> T21JYM_20200126T134201_B02_10m, 2 * T21JYM_20200126T134201_B03_10m,
> 2 * T21JYM_20200126T134201_B04_10m))) == 0) &&
> ((T21JYM_20200126T134201_B02_10m > 0.2) == 1), 0, null())
> I checked the xml file and there are a lot of nan's yes, but there are
> also real values. Why doesn't the max function in this part:
> https://github.com/OSGeo/grass-addons/blob/master/grass7/imagery/i.sentinel/i.sentinel.mask/i.sentinel.mask.py#L321
> recognize them? Isn't there a way to avoid nan while computing max?
> Thanks much in advance
> Vero
> ps: I can provide the xml if needed.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200129/b805dd52/attachment-0001.html>
