[GRASS-user] R: error in i.sentinel.mask: nan values in xml file
roberta fagandini robifagandini at hotmail.it
Thu Jan 30 04:49:05 PST 2020
Hi Vero,
I have just tested i.sentinel.mask using your image and the command ended without errors (computational region set to the extension fo the image - location wgs84/utm21).
i.sentinel.mask -s
blue=T21JYM_20200126T134201_B02_10m at test_vero
green=T21JYM_20200126T134201_B03_10m at test_vero
red=T21JYM_20200126T134201_B04_10m at test_vero
nir=T21JYM_20200126T134201_B08_10m at test_vero
nir8a=T21JYM_20200126T134201_B8A_20m at test_vero
swir11=T21JYM_20200126T134201_B11_20m at test_vero
swir12=T21JYM_20200126T134201_B12_20m at test_vero
cloud_mask=v_cloud
cloud_raster=r_cloud
shadow_mask=v_shadow
shadow_raster=r_shadow
cloud_threshold=50000
shadow_threshold=10000
mtd_file=S2A_MSIL2A_20200126T134201_N0213_R124_T21JYM_20200126T154908\S2A_MSIL2A_20200126T134201_N0213_R124_T21JYM_20200126T154908.SAFE\GRANULE\L2A_T21JYM_A024002_20200126T134204\MTD_TL.xml
I'm using GRASS 7.8.2 on Windows 8 (please don't judge 😄) .
In your case, the error occurs while computing the east and north clouds shift in particular during the v.overlay process. I think the error message you get is not a message defined in the code but a standard error message from GRASS so I don't know which error output it refers to.
Ciao
Robi
Da: Veronica Andreo <veroandreo at gmail.com>
Inviato: mercoledì 29 gennaio 2020 23:14
A: roberta fagandini <robifagandini at hotmail.it>
Cc: grass-user <grass-user at lists.osgeo.org>
Oggetto: Re: [GRASS-user] error in i.sentinel.mask: nan values in xml file
Hi Robi,
So I found that i.sentinel.import fails for latlong locations. I moved to UTM as in the original data and all fine. I reached the cloud masking step, and I find a different problem now.
Here's the command and an extract of the output:
GRASS 7.9.dev<http://7.9.dev> (dengue_cba):~/webgis > i.sentinel.mask -s \
>   blue=$blue \
>   green=$green \
>   red=$red \
>   swir11=$swir11 \
>   nir=$nir \
>   swir12=$swir12 \
>   nir8a=$nir8a \
>   cloud_raster=cloud \
>   shadow_raster=shadow \
>   mtd_file=`find $out_dir -name 'MTD_TL.xml'` \
>   scale_fac=10000
WARNING: All subsequent operations will be limited to the current
--- Start rescaling bands ---
 100%
 100%
 100%
 100%
 100%
 100%
 100%
T21JYM_20200126T134201_B02_10m_double,T21JYM_20200126T134201_B03_10m_double,T21JYM_20200126T134201_B04_10m_double,T21JYM_20200126T134201_B08_10m_double,T21JYM_20200126T134201_B8A_20m_double,T21JYM_20200126T134201_B11_20m_double,T21JYM_20200126T134201_B12_20m_double
--- All bands have been rescaled ---
--- Start computing maximum values of bands ---
--- Computed maximum value: dict_values([0.9352, 1.168, 1.1056, 1.0704,
0.7023, 0.9381, 1.3597]) ---
--- Statistics have been computed! ---
--- Start clouds detection procedure ---
--- Computing cloud mask... ---
 100%
--- Converting raster cloud mask into vector map ---
Extracting areas...
 100%
Writing areas...
 100%
Building topology for vector map <cloud_v_5922 at carla>...
Registering primitives...
Building areas...
 100%
Attaching islands...
 100%
Attaching centroids...
 100%
r.to.vect complete.
--- Cleaning geometries ---
--- Start removing misclassification from the shadow mask ---
--- Data preparation... ---
WARNING: Values in column <cat> will be overwritten
WARNING: Number of centroids exceeds number of areas: 24 > 22
WARNING: Number of duplicate centroids: 2
--- Reading mean sun zenith and azimuth from metadata file to compute
clouds shift ---
--- the mean sun Zenith is: 28.732 deg ---
--- the mean sun Azimuth is: 82.028 deg ---
--- Start computing the east and north clouds shift at steps of 100m of
clouds height---
  File "/home/veroandreo/.grass7/addons/scripts/i.sentinel.mask", line 638, in <module>
    main()
  File "/home/veroandreo/.grass7/addons/scripts/i.sentinel.mask", line 561, in main
    quiet=True, stderr=subprocess.DEVNULL)
  File "/home/veroandreo/software/grass79-dev/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py", line 499, in run_command
    return handle_errors(returncode, result=None, args=args, kwargs=kwargs)
  File "/home/veroandreo/software/grass79-dev/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py", line 392, in handle_errors
    returncode=returncode)
grass.exceptions.CalledModuleError: Module run v.overlay v.overlay --o --q ainput=addcat_5922 binput=cl_shift_5922 operator=and output=overlay_5922 ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
Where is this error output to inspect?
This is the UUID in case you want to test: 541021f8-63f5-4e9d-ba28-425c4c8451df
Thanks much in advance
Vero
ps: I use grass-dev with python 3.7.4 (because of the ctypes issue)
El mié., 29 ene. 2020 a las 14:53, Veronica Andreo (<veroandreo at gmail.com<mailto:veroandreo at gmail.com>>) escribió:
Hi Robi,
My bad, region was wrong... anyway, trying to replicate from the beginning I see that i.sentinel.import with -r is importing empty maps. However, the jp2 files have data. I can visualize them in QGIS. I'll report in a different thread. Once I can figure it out and reach this point again, I'll report back to you. Thanks for the clarification!
Cheers
Vero
El mié., 29 ene. 2020 a las 9:08, roberta fagandini (<robifagandini at hotmail.it<mailto:robifagandini at hotmail.it>>) escribió:
Hi Vero,
i.sentinel.mask doesn't retrieve the maximum from the xml file but computes the value from the image using r.univar. The error could be due to the computational region..has the region been set correctly?
Can you send the MTD_TL.xml file? I can download the image and make some tests.
Roberta
Da: grass-user <grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>> per conto di Veronica Andreo <veroandreo at gmail.com<mailto:veroandreo at gmail.com>>
Inviato: martedì 28 gennaio 2020 19:57
A: grass-user <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Oggetto: [GRASS-user] error in i.sentinel.mask: nan values in xml file
Hello
I try to use i.sentinel.mask but I get the following error:
i.sentinel.mask blue=$blue green=$green red=$red swir11=$swir11 nir=$nir swir12=$swir12 nir8a=$nir8a cloud_mask=cloud shadow_mask=shadow mtd_file=`find $out_dir -name 'MTD_TL.xml'`
ADVERTENCIA: All subsequent operations will be limited to the current
ADVERTENCIA: Any rescale factor has been applied
--- Computed maximum value: dict_values([nan, nan, nan, nan, nan, nan,
nan]) ---
Mapa no válido <nan>
Parse error
ERROR: error al parsear
ERROR: An error occurred while running r.mapcalc with expression:
       cloud_def82115 = if((((T21JYM_20200126T134201_B02_10m > (0.08*nan))
       && (T21JYM_20200126T134201_B03_10m > (0.08*nan)) &&
       (T21JYM_20200126T134201_B04_10m > (0.08*nan))) == 1) &&
       (((T21JYM_20200126T134201_B04_10m < ((0.08*nan)*1.5)) &&
       T21JYM_20200126T134201_B12_20m*1.3)) == 0) &&
       (((T21JYM_20200126T134201_B11_20m < (0.1*nan)) &&
       (T21JYM_20200126T134201_B12_20m < (0.1*nan))) == 0) &&
       ((if(T21JYM_20200126T134201_B8A_20m ==
       max(T21JYM_20200126T134201_B8A_20m, 2 *
       T21JYM_20200126T134201_B02_10m, 2 * T21JYM_20200126T134201_B03_10m,
       2 * T21JYM_20200126T134201_B04_10m))) == 0) &&
       ((T21JYM_20200126T134201_B02_10m > 0.2) == 1), 0, null())
I checked the xml file and there are a lot of nan's yes, but there are also real values. Why doesn't the max function in this part: https://github.com/OSGeo/grass-addons/blob/master/grass7/imagery/i.sentinel/i.sentinel.mask/i.sentinel.mask.py#L321 recognize them? Isn't there a way to avoid nan while computing max?
Vero
ps: I can provide the xml if needed.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200130/b376dc66/attachment-0001.html>
