[GRASS-user] [R-sig-Geo] [R] Need help using GRASS within R - error when running the script for a second time
Roger Bivand
Roger.Bivand at nhh.no
Tue Jul 7 11:20:55 PDT 2020
Please do not cross-post between lists, because few are likely to
subscribe to both. Choose rather to post only to the list likely to
include people using R and GRASS:
http://lists.osgeo.org/mailman/listinfo/grass-stats
Further, please post plain text only - I missed your earlier post to
grass-user because it was scrubbed as HTML (or maybe Micha's reply).
Once resolved, you might report back on grass-user and R-sig-geo on the
findings.
Briefly, it looks as though you are caught in the transition in sp/rgdal
and sf from Proj4 to WKT2-2019 CRS, and similar changes in Grass. Grass
7.8 and R packages may be installed with old PROJ/GDAL or new PROJ/GDAL.
So far, nobody knows how to use g.proj and siblings sensibly in the R
context. Most likely, using the wkt= parameter when the object in R has a
WKT2 representation is going to be much more secure than passing a proj4=
string, but wkt= takes a file name or standard input.
I would invite discussion in an issue on:
https://github.com/rsbivand/rgrass7/issues
with use cases (platform-independent).
Roger
On Tue, 7 Jul 2020, Loïc Valéry wrote:
> Dear all,
> As advised by Micha (FYI his reply is at the end of this email) , I
> contact you to submit an inextricable problem when using rgrass7 : the
> script (cf. just below) works the first time but, when I rerun it a
> second time, R and windows return error messages. For this to work, I
> must close and open R or use the rs.restartR() command from RStudio,
> which is not very convenient because it stops the script.
> Many thanks in advance for your help.
> Loïc
> @Micha : thank you very much for your reply. But I performed the tests
> you asked me to do and, unfortunately, none of them solve the problem.
> Also, I tried to run "execGRASS("g.proj", flags = "c", proj4 = p4str)" a
> second time WITHOUT reinitializing GRASS but R and windows still return
> the same error messages.
> ERRORS WHEN I RUN THE SCRIPT FOR A SECOND TIME :
> - FROM WINDOWS : g.region.exe : the procedure entry point GEOSMakeValid_r could not be located in the dynamic link library C:\Program Files\GRASS GIS 7.8\extrabin\gdal300.dll
> - FROM R :
> # Link to GRASS GIS software v.7.8.3
>> initGRASS(gisBase ="C:/Program Files/GRASS GIS 7.8",
> + home="temp/GRASS_tmp", use_g.dirseps.exe=F,
> + gisDbase="temp/GRASS_tmp", mapset="PERMANENT",
> + remove_GISRC=T, override=T)
> Error in if (is.na(projstr)) uprojargs <- projstr else uprojargs <- paste(unique(unlist(strsplit(projstr, :
> l'argument est de longueur nulle
> De plus : There were 50 or more warnings (use warnings() to see the first 50)
>> # Specifying the projection reference for the GRASS working environment
>> p4str<-sp::proj4string(seg_poly)
> Warning message:
> In sp::proj4string(seg_poly) :
> CRS object has comment, which is lost in output
>> rgrass7::use_sp()
>> # Converting the 'sp' object into a GRASS-readable file format (here, 'vec1.shp')
>> writeVECT(seg_poly,"vec1",v.in.ogr_flags=c("o", "overwrite"),
> + driver="ESRI Shapefile")
> Error in writeVECT(seg_poly, "vec1", v.in.ogr_flags = c("o", "overwrite"), :
> driver %in% candDrivers is not TRUE
> De plus : Warning message:
> In system(syscmd, intern = intern, ignore.stderr = ignore.stderr, :
> l'exécution de la commande 'v.in.ogr.exe -f' renvoie un statut 313
>> # Run the 'v.generalize' function
>> execGRASS("v.generalize",flag=c("overwrite"),
> + parameters=list(input="vec1",
> + output="GRASS_smooth_seg_poly",
> + error="GRASS_smooth_seg_poly_error",
> + method="distance_weighting",
> + threshold=1))
>> # Converting the shapefile 'GRASS_smooth_seg_poly.shp' into a R-readable object
>> # (here, a SpatialPolygonDataFrame named 'smooth_seg_poly')
>> smooth_seg_poly<-readVECT("GRASS_smooth_seg_poly", with_prj=T,
> Error in .read_vect_non_plugin(vname = vname, layer = layer, type = type, :
> REPLY FROM MICHA :
> De : Micha Silver <tsvibar at gmail.com>
> Envoyé : mardi 7 juillet 2020 15:55
> À : Loïc Valéry <lvalery at outlook.fr>
> Cc : grass-user <grass-user at lists.osgeo.org>
> Objet : Re: [R] Need help using GRASS within R - error when running the script for a second time
> Hello Loïc
> Let's keep the discussion on the list, so others can help and benefit from responses.
> BTW, you might want to post to the r-sig-geo list also. If you come across questions specific to R and spatial functions, that's the best place to ask.
> Below,inline, some guesses as to what is happening...
> I'm not sure, but I don't think you want to rerun initGRASS() a second time. In your script, you do initGRASS only once, then if you need to perform several analyses, do them in the same (running) GRASS session.
> Warning message:
> rgrass7::use_sp()
> The driver name is "ESRI_Shapefile" (note the underscore). Perhaps that is the problem here?
> + threshold=1))
> Same here, the driver name for shapefile is wrong.
> I would also add that both R and GRASS have switched to the better Geopackage format for exchanging spatial data. You might want to try, the driver name is "GPKG"
> See details about Geopackage here:
> https://www.gis-blog.com/geopackage-vs-shapefile/
> and in French here:
> https://www.sigterritoires.fr/index.php/le-format-geopackage-et-qgis-3/
> Best, Micha
> PREVIOUS EMAILS:
> Envoyé : mardi 9 juin 2020 23:08
> Objet : Re: [R] Need help using GRASS within R - problem with CRS using the 'v.generalize' command
> On 09/06/2020 16:22, Loïc Valéry wrote:
> Dear Micha,
> A thousand thanks for your help. It works now!
> Whoa, you'd better save some thanks for the next question. ;-)
> For your information and following your remark, I also updated rgdal.
> Thanks again for taking the time to answer me.
> Kind regards
> Loïc
> Envoyé : mardi 9 juin 2020 08:44
> À : Loïc Valéry <lvalery at outlook.fr>; r-help at R-project.org <r-help at R-project.org>
> Hello
> On 08/06/2020 19:52, Loïc Valéry wrote:
> Dear all,
> First of all, this is my first message on the list. Therefore, please be indulgent if my message is not perfectly formatted as it should be.
> I am currently encountering a difficulty with GRASS 7.8 within R when using the 'v.generalize' command to smooth the contour of polygons after a segmentation step.
> I tried two different ways to "call" GRASS:
> 1 - using the RQGIS3 package
> setwd("D:/test")
> library(sp)
> library(rgdal)
> rgdal: version: 1.4-8, (SVN revision 845)
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 2.2.3, released 2017/11/20
> Path to GDAL shared files: C:/Users/toto/Documents/R/win-library/3.6/rgdal/gdal
> GDAL binary built with GEOS: TRUE
> Loaded PROJ.4 runtime: Rel. 4.9.3, 15 August 2016, [PJ_VERSION: 493]
> Path to PROJ.4 shared files: C:/Users/toto/Documents/R/win-library/3.6/rgdal/proj
> Linking to sp version: 1.4-1
> Please note that you have older versions of GDAL (2.2.3 here) and PROJ.4
> (4.9 here). These are currently being replaced by GDAL 3.0 and PROJ 6.3.
> You might (should) want to follow the discussion the the r-sig-geo maillist:
> https://stat.ethz.ch/pipermail/r-sig-geo/2020-June/028165.html
> ....... (skipped all the discussion regarding RQGIS3 as I think it's not
> relevant)
> setwd("D:/test")
> library(rgrass7)
> # characteristics of the SpatialPolygonsDataFrame 'seg_poly' : CRS does exist
> seg_poly
> class : SpatialPolygonsDataFrame
> features : 31
> extent : 477371.3, 477397.6, 5631995, 5632020 (xmin, xmax, ymin, ymax)
> crs : +proj=utm +zone=32 +datum=WGS84 +units=m +no_defs
> variables : 1
> names : Seg_ID
> min values : 1
> max values : 31
> Warning message:
> In proj4string(x) : CRS object has comment, which is lost in output
> # initialization of GRASS 7.8 from R
> initGRASS(gisBase ="C:/Program Files/GRASS GIS 7.8", home="temp/GRASS",gisDbase="temp/GRASS", use_g.dirseps.exe=F,remove_GISRC=T, override=T)
> gisdbase temp/GRASS
> location file19685026c56
> mapset file196829fa7141
> rows 1
> columns 1
> north 1
> south 0
> west 0
> east 1
> nsres 1
> ewres 1
> projection NA
> I suspect that the problem comes from 'projection NA' when initializing GRASS (cf. just above)
> What you need to do here is setup the CRS of your new location.
> Typically, you would run initGRASS and point to a *previously created*
> LOCATION, with CRS already defined. In this case, since you are creating
> a new location, you must define it's coordinate system. (GRASS is very
> "picky" about that).
> Here's a GIS Stackexchange post that explains:
> https://gis.stackexchange.com/questions/183032/create-a-new-grass-database-in-r-with-crs-projection
> You can derive the full proj4 string from your sp object with:
> p4str = sp::proj4string(seg_poly)
> Then use that to set the project parameters for the new LOCATION, with
> execGRASS("g.proj", flags = "c", proj4 = p4str) Now you should be able
> to continue with...
> execGRASS("v.generalize",flag=c("overwrite"),parameters=list(input="vec1",
> + threshold=1))
> As a novice in the field, I would be very grateful for your help.
> I remain at your entire disposal for any further information you may need to help me in finding a solution to this problem.
> Yours sincerely,
> Loïc
> ______________________________________________
> R-help at r-project.org mailing list -- To UNSUBSCRIBE and more, see
> https://stat.ethz.ch/mailman/listinfo/r-help
> PLEASE do read the posting guide http://www.R-project.org/posting-guide.html
> and provide commented, minimal, self-contained, reproducible code.
Roger Bivand
Department of Economics, Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
https://orcid.org/0000-0003-2392-6140
https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
