[GRASS-user] Reclassify a vector adding a column
    Margherita Di Leo
    diregola at gmail.com
    Wed Jun 17 09:38:43 PDT 2020
Dear Micha,
On Wed, Jun 17, 2020 at 4:05 PM Micha Silver <tsvibar at gmail.com> wrote:
> On 17/06/2020 16:14, Margherita Di Leo wrote:
> Ciao Stefan,
> thank you, I tried and it didn't give me any error but didn't update the
> column either...
> The sqlite CASE statement should be:
> CASE <old_column> WHEN '<old_val1>' THEN '<new_val1>' WHEN '<old_val2>'
> THEN '<new_val2>'....END;
> Here's an example that worked for me. I have a "myroads" vector with
> column 'TYPE'
> # Add new column for road width as text
> v.db.addcolumn myroads column="width TEXT"
> # Run update with CASE
> db.execute sql="UPDATE myroads SET width=CASE TYPE WHEN 'Main' THEN 'Wide'
> WHEN 'Local' THEN 'Narrow' ELSE 'Unknown' END;"
> Best, Micha
This worked! Thank you so much! I have one last question. Does it also
support an IS LIKE condition, and if yes, how can I express it?
Thanks!
Margherita Di Leo
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200617/e1ac0f0d/attachment.html>
