[GRASS-user] Import Shape Files
Markus Neteler
neteler at osgeo.org
Thu Jun 25 12:44:38 PDT 2020
(please keep the list in CC)
On Thu, Jun 25, 2020 at 1:57 PM Martin Bittens <martin.bittens at gmx.de> wrote:
> Hello Markus,
> thank you for your reply.
> Usually I am creating locations and map sets with the GRASS start-up
> screen. After opening my 31983 location/mapset the command "g.proj -w"
> results in:
> PROJCS["SIRGAS 2000 / UTM zone 23S",
> GEOGCS["SIRGAS 2000",
> DATUM["Sistema_de_Referencia_Geocentrico_para_las_AmericaS_2000",
> SPHEROID["GRS 1980",6378137,298.257222101,
> AUTHORITY["EPSG","7019"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6674"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9122"]],
> AUTHORITY["EPSG","4674"]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",-45],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",10000000],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AXIS["Easting",EAST],
> AXIS["Northing",NORTH],
> AUTHORITY["EPSG","31983"]]
> This is almost the same result you sent. Just line appears in addition:
> TOWGS84[0,0,0,0,0,0,0].
> Using the command "grass78 -c epsg:31983 ~/grassdata/utm31983" like you
> did "g.proj -w" results in:
> UNIT["metre",1,
> This looks exactly like the result you sent.
Ok, that looks fine to me.
> But anyhow, it does not
> matter how I am creating locations/mapsets imported shape files are
> showing in the meta data results "Projection UTM (zone invalid).
Then maybe the .proj file of te shape file(s) is incomplete?
Can you make one file available (even off-list)?
Best
Markus
