[GRASS-user] python 'NamError' r.landscape.evol
Helmut Kudrnovsky
hellik at web.de
Fri May 1 23:27:04 PDT 2020
Maria Cecilia Zalazar wrote
> Hello. In previous (win)grass versions I was able to work with
> r.landscape.evol addon. Now with 7.8.2 wingrass version appears a python
> NameError:
> *r.landscape.evol elev=DEM_21x21 at PERMANENT initbdrk=0 smoothing=no
> prefx=levol_test outdem=elevation_test outsoil=soildepth_test number=1*
> *Traceback (most recent call last):*
> * File "C:\Users\USUARIO\AppData\Roaming\GRASS7\addons/scrip*
> *ts/r.landscape.evol.py <http://r.landscape.evol.py/>", line 665, in
> <module>
> * f = file(statsout, 'wt')*
> *NameError: name 'file' is not defined*
> It seems that the script was written in Python < 3 and ‘file()’ is not
> supported in Python 3. Is possible that the addon needs to transform into
> valid Python 3.x code?
> Thanks for your help!
> grass-user mailing list
> grass-user at .osgeo
> https://lists.osgeo.org/mailman/listinfo/grass-user
I opened an issue here:
https://github.com/OSGeo/grass-addons/issues/156
Just comment or if you have a solution, open a PR there
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
