[GRASS-user] Global Hydrological modeling with r.watershed, r.stream.extract, r.stream.extract
hindo kush
hindokush12 at gmail.com
Wed May 6 02:14:31 PDT 2020
Great job.
On Tue, May 5, 2020 at 11:56 AM Giuseppe Amatulli <
giuseppe.amatulli at gmail.com> wrote:
> Dear GRASS Team
> I am running a global analysis where I need to use "tiles" as
> computational units in which I use the following three commands:
> r.watershed -b elevation=elv depression=dep accumulation=flow
> drainage=dir_rw flow=pixel_area memory=100000 --o --verbose
> r.stream.extract elevation=elv accumulation=flow depression=dep
> threshold=0.05 direction=dir_rs stream_raster=stream memory=100000 --o
> --verbose
> r.stream.basins -l stream_rast=stream direction=dir_rs basins=lbasin
> The basins that were not completely within a tile (resulting in
> broken-basins) have been removed (see below the three tiles in Figs. 1,2,3
> including only entire basins),
> and now I'm in the phase of merging all the tiles having only complete
> basins.
> When I merge the tiles (Fig 4), some basin borders do not match perfectly,
> and some areas have NoData (see Fig 5,6) or have the Basin ID of the below
> basin (Fig 7).
> I noticed that these phenomena appear only when I merge tiles that have
> very large broken-basins that can not be included in the tile due to RAM
> limitations.
> My thought is that r.stream.basins needs the entire dimension of two
> adjacent basins to be able to detect the border without gap and without a
> potential random selection.
> Is there any part of the r.stream.basins code that I can potentially check
> and eventually hack to avoid this problem?
> For the rest, all the RAM limitation and other problem have been solved
> soon we will have a global stream network and basin delineation performed
> 100% in GRASS!!!
> Thank you
> Best Regards
> Giuseppe
> Fig 1. Left Tile
> [image: image.png]
> Fig 2. Center tile
> [image: image.png]
> Fig 3. Right Tile
> [image: image.png]
> Fig 4. Merge all the tiles
> [image: image.png]
> Fig 5. Gap -> small white area
> [image: image.png]
> Fig 6. Gap -> small white area
> [image: image.png]
> Fig 7. boarder Basins inconsistency among tiles
> [image: image.png]
> Giuseppe Amatulli, Ph.D.
> Research scientist at
> School of Forestry & Environmental Studies
> Center for Research Computing
> Yale University
> New Haven, CT, USA
> 06511
> Teaching: http://spatial-ecology.net
> Work: https://environment.yale.edu/profile/giuseppe-amatulli/
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/335515c9/attachment-0013.png>
