[GRASS-user] Creating an R Container with GRASS support
Mehrdad Varedi
varedi at waterlix.com
Thu May 21 05:37:28 PDT 2020
Hi Markus,
I used the Dockerfile you shared and began from the r-base instead of
ubuntu, it worked very well. Only, the image is a little big which is more
a docker issue.
If you have any recommendations, I would appreciate it, although this is
not a GRASS question.
Thanks and Kind regards,
Mehrdad
Mehrdad Varedi, M.A.Sc.
Waterlix <http://www.waterlix.com> Inc. Founder
www.waterlix.com
Cell: +1 (519)722-7057
On Wed, May 20, 2020 at 4:10 AM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Mehrdad,
> On Wed, May 20, 2020 at 9:06 AM Mehrdad Varedi <varedi at waterlix.com>
> wrote:
>> Hi everybody,
>> my hope is to reference the necessary files and folders or copy them on
>> an R image to use GRASS functions in R.
>> I have a Docker file like the following:
>> *FROM neteler/grassgis7 as thegrass*
>> *FROM rocker/rstudio*
>> *COPY --from=thegrass /usr/local/grass79 /usr/local/grass79*
> Here you only copy (if I am not mistaken) the grass79 folder but not the
> related system-wide installed PROJ, GDAL etc libs.
> They are in /usr/lib[64]/... (don't know precisely right now).
>> *COPY --from=thegrass /data /data*
>> *COPY --from=thegrass /home/grass /home/grass*
>> *RUN sudo apt-get install -y libcurl4-openssl-dev libxml2-dev*
> I suppose you also need to install the geo software stack here as well (see
> https://hub.docker.com/r/neteler/grassgis7/dockerfile
>> Then I build and run the image which has a few folders from GRASS GIS
>> In RStudio, I install and call the "rgrass7" and "raster" libraries. (No
>> errors)
>> Then in Rstudio, I try to run the initGRASS function with the following
>> values:
>> initGRASS(gisBase = "/usr/local/grass79", home = raster::tmpDir(), gisDbase = "tmpDbase", location = "Kitchener", mapset = "PERMANENT", override = TRUE)
>> This is the error I recieve:Error in parseGRASS(cmd, legacyExec = legacyExec) : The command
>> g.region --interface-description
>> could not be run (127), and produced the error message:
>> g.region: error while loading shared libraries: libproj.so.12: cannot open shared object file: No such file or directory
> Yes, because it isn't there yet (see above).
> Hope this helps,
> Markus
> In addition: Warning message:In system2(command = command, args = arguments, stdout = outFile, : error in running command
>> Do you know a better way to merge the GRASS GIS files with the R image?
>> Would you please help me to complete the Dockerfile to avoid such errors?
>> Kind regards,
>> Mehrdad
>> www.waterlix.com
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200521/467a845d/attachment.html>
