[GRASS-user] 7.9.dev: which wxPython versions supprted?
Rich Shepard
rshepard at appl-ecosys.com
Mon May 25 15:34:33 PDT 2020
> From neteler at osgeo.org Mon May 25 14:35:42 2020
Rich,
did you see
https://github.com/OSGeo/grass/issues/649
To which I responded,
> Nope. I'll grab wxPython-4.1.0 and see if it builds with the SBo script.
Here's the latest;
I'm moving this to the user mail list because I'm not subscribed to the dev
mail list.
I downloaded wxPython-7.1.0 source code, changed the version number in the
SlackBuilds.org (SBo) build script, and the build completed without errors
other than a couple of empty metadata files.
However, when I try to start 'grass79 -gui' it fails with these errors:
$ grass79 -gui
Starting GRASS GIS...
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:96:
'caret-color' is not a valid property name
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:97:
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:94:
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:122:
(gis_set.py:20526): Gtk-WARNING **: Theme parsing error: <data>:1:135:
File "/usr/local/grass79/gui/wxpython/gis_set.py", line 1148, in OnInit
StartUp = GRASSStartup()
File "/usr/local/grass79/gui/wxpython/gis_set.py", line 224, in __init__
self._do_layout()
File "/usr/local/grass79/gui/wxpython/gis_set.py", line 399, in _do_layout
description=self.llocation)
File "/usr/local/grass79/gui/wxpython/gis_set.py", line 376, in
layout_list_box
border=1)
wx._core.wxAssertionError: C++ assertion "!(flags & wxALIGN_CENTRE_HORIZONTAL)"
failed at /tmp/SBo/wxPython-4.1.0/ext/wxWidgets/src/common/sizer.cpp(2106) in
DoInsert(): Horizontal alignment flags are ignored in horizontal sizers
OnInit returned false, exiting...
ERROR: Error in GUI startup. See messages above (if any) and if necessary,
please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package,
probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use '--help' for further options
grass79 --help
See also: https://grass.osgeo.org/grass79/manuals/helptext.html
Exiting...
Is this a grass issue or an SBo issue? If the latter I'll let the package
maintainer know and he'll probably have it fixed tomorrow.
Regards,
Rich
