[GRASS-user] Estimating import time for large data file
Rich Shepard rshepard at appl-ecosys.com
Fri May 29 05:37:03 PDT 2020
On Fri, 29 May 2020, Moritz Lennert wrote:
> Importing such a large file can take a lot of time because of the cleaning in
> order to get it into GRASS GIS' topological format.
Moritz,
I assumed it would taka a while, but it seemed to be stuck. Perhaps because
that polygon was large, complex, and needed a lot of cleaning.
> I think it really depends on the specific file in terms of geometry
> complexity and cleanliness, so difficult to pre-determine. I regularly
> launch large import jobs overnight.
Then that's what I'll do tonight: I'll start it running in screen before I
log off and let it do it's thing for as long as it wants.
> You should see an information about its progress in the different cleaning
> steps (note that some cleaning is repeated).
I was using the GUI because I needed to create a new location and have
forgotten how to create a new location and mapset from the command line.
> If you are sure you do not want to do any polygon cleaning during import, you
> can use the -c flag. But you will have to handle the result with care.
Actually, I much prefer to let GRASS clean as it goes.
Thanks very much for the knowledge.
Stay well,
Rich
