[GRASS-user] Estimating import time for large data file
Rich Shepard
rshepard at appl-ecosys.com
Fri May 29 06:19:20 PDT 2020
On Fri, 29 May 2020, Moritz Lennert wrote:
> grass --help is your friend ;-)
Moritz,
Good to know; I never tried this.
> grass -c epsg:4326 GISDBASE/LOCATION
> replace GISDBASE and LOCATION with the respective names
> -c can also be used with a file:
> -c /path/to/georeferenced/file
Thanks for the reminder.
> Another, untested, path for possibly speeding up import: use ogr2ogr with
> the -simplify option to first simplify the geometry, if that is possible
> in your case. Would be interesting to benchmark v.in.ogr alone against
> ogr2ogr -simply + v.in.ogr.
I'll consider doing this test. When I run a shell script, or the command for
a long running process, I use the 'time' tool with it.
Regards,
Rich
