[GRASS-user] [GRASS-dev] grass python problem
    Maris Nartiss
    maris.gis at gmail.com
    Tue Nov 17 01:03:10 PST 2020
Please provide more information:
GRASS version
Python version
exact error message
I did not observe any errors while running command you provided (of
course I used different map names to match map names I had on my
system).
Māris.
otrd., 2020. g. 17. nov., plkst. 06:04 — lietotājs ming han
(<dustming at gmail.com>) rakstīja:
> Hi Everyone
>     Hope this email finds you well.
>     I can run r.cross in console with following command:
>     "r.cross -z --overwrite --quiet input=Connect_Lake at PERMANENT,str_grass_r at PERMANENT output=test"
>     But I got error by run r.cross in python with following command:
>     grass.run_command('r.cross', input = ['str_grass_r at PERMANENT','Connect_Lake at PERMANENT'],output = 'test', quiet = True)
>      What is the correct format to use r.cross function in Python? and how to obtain the output table generated by r.cross?
> Thanks
> Ming
