[GRASS-user] Unable to perform resampling
Veronica Andreo veroandreo at gmail.com
Mon Nov 23 15:40:33 PST 2020
Well, yes, there's the mailing list, posts with questions in
https://gis.stackexchange.com, twitter account and facebook community, and
the issues in the GitHub repo for reporting bugs or proposing new features.
Moreover, you can check https://grass.osgeo.org/learn/ for plenty of other
resources (tutorials, courses, books, etc.) and the wiki (
https://grasswiki.osgeo.org/wiki/GRASS-Wiki).
I believe mailing lists work better for most of us. Also, that's where you
can reach a larger audience. Having to check yet another platform to see if
there are questions that are mostly already answered in the mailing list
archives, tutorials or the wiki seems like a bit too much to me. However,
if someone else is willing to manage such a forum, they are most welcome :)
best,
Vero
El lun, 23 nov 2020 a las 23:22, BHARATH RAM (<br11 at iitbbs.ac.in>) escribió:
> Okay, thanks for the clarification.
> (Also, I will remember to cc the list in future).
> I have one more question if it's okay to ask(not related to above issue).
> I understand Grass GIS queries & issues are resolved through mailing lists
> at the moment and the archives. Not meaning to be disrespectful of the
> community, but won't it be much useful when we have a forum like website to
> post & answer each others queries (it can especially be useful since
> newcomers like me don't have to flood the mailing list with common issues)?
> Thank you.
> Regards,
> Bharath Ram.
> On Tue, Nov 24, 2020, 3:30 AM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> [cc-ing the list]
>> The examples in the manuals are in meters because they are based on the
>> North Carolina sample dataset which CRS is Lambert Conformal Conic. The
>> units of this CRS are meters.
>> g.proj -p
>> -PROJ_INFO-------------------------------------------------
>> name       : Lambert Conformal Conic
>> proj       : lcc
>> datum      : nad83
>> a          : 6378137.0
>> es         : 0.006694380022900787
>> lat_1      : 36.16666666666666
>> lat_2      : 34.33333333333334
>> lat_0      : 33.75
>> lon_0      : -79
>> x_0        : 609601.22
>> y_0        : 0
>> no_defs    : defined
>> -PROJ_UNITS------------------------------------------------
>> unit       : Meter
>> units      : Meters
>> meters     : 1
>> You have to adjust to the units of the CRS that you use when it comes to
>> resolution. There's no way to set resolution in meters if you work in
>> latlong. Hence the recommendation to work in projected systems.
>> Some modules might use distance in meters for certain parameters even
>> when working in latlong, because they convert such distances within the
>> source code into radians (if I'm not mistaken). If not, they will raise a
>> warning. Again, to avoid such issues, it's a good practice to work with
>> projected CRS.
>> best,
>> Vero
>> El lun, 23 nov 2020 a las 22:46, BHARATH RAM (<br11 at iitbbs.ac.in>)
>> escribió:
>>> Dear Ms.Veronica Andreo,
>>>   Thank you very much for your quick reply.  Yes your suggestion works
>>> correctly.
>>> But I find it a litttle suprising since in the documentation (for
>>> modukes like r.resample.stats, r.sun etc..) & in several examples meter
>>> seems to be the default units used for distance and I assumed that for my
>>> case as well it was the same (even though g.region -p prints out in decimal
>>> degree).
>>> Is there any way to change the units back to meter as default?
>>> Thank you
>>> Regards,
>>> Bharath
>>> On Tue, Nov 24, 2020, 3:03 AM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>>> Hello Bharath,
>>>> I think your problem is that you are working in a latlong location and
>>>> trying to set a resolution of 8000 degrees, which is not possible. If your
>>>> desired final resolution is ~8 km, you will need to set the region
>>>> resolution to its equivalent in degrees (the unit of latlong CRS).
>>>> Otherwise, work with projected CRS like UTM for example (recommended).
>>>> Furthermore, if you want to go from high res to lower res (upscaling),
>>>> r.resamp.stats is your friend, so the second approach would be fine. The
>>>> problem lays in the resolution you are setting.
>>>> HTH,
>>>> Vero
>>>> El lun, 23 nov 2020 a las 22:20, BHARATH RAM (<br11 at iitbbs.ac.in>)
>>>> escribió:
>>>>> Hello everyone,
>>>>>     I am interested in performing resampling of a fine resolution DEM
>>>>> Model (which is imported as a GTiff file in grass GIS). I tried the
>>>>> following 2 approaches and neither of them was successful. Can you help me
>>>>> figure out where I went wrong? Thanks in Advance.
>>>>> *Details about originally imported DEM model:*
>>>>> *projection: 3 (Latitude-Longitude)*
>>>>> *zone:       0datum:      wgs84ellipsoid:  wgs84north:      29Nsouth:
>>>>>      28:06Nwest:       72Eeast:       77:24Ensres:      0:00:01.08ewres:
>>>>>    0:00:01.08rows:       3000cols:       18000cells:      54000000*
>>>>> *MY AIM:* To convert a fine grid DEM (30 m resolution) to coarse grid
>>>>> DEM (8km)
>>>>> *APPROACH 1: Using r.resample.rst*
>>>>> *g.region raster=test5_r1*
>>>>> *r.resamp.rst input=test5_r1 ew_res=8000 ns_res=8000   *
>>>>>   In this second command's execution, I get error (log attached below):
>>>>> *                Processing all selected output files will require **4
>>>>> bytes of disk space for temp files.*
>>>>> *                Temporarily changing the region to desired resolution
>>>>> ...                Changing back to the original region ...
>>>>> Percent complete:                ERROR: Unable to seek: Invalid argument*
>>>>> *APPROACH 2: Using r.resample.stats*
>>>>> *g.region nsres=8000 ewres=8000 *// problematic part
>>>>> *r.resamp.stats -w input=test5_r1 output=test5_r1_8km*
>>>>>    In this second command's execution the entire map seems to get
>>>>> clubbed into a single large pixel. I have attached results of *g.region
>>>>> -ap* below:
>>>>> *                projection: 3 (Latitude-Longitude)*
>>>>> *                 zone:       0                 datum:      wgs84
>>>>>             ellipsoid:  wgs84                 north:      29N
>>>>>   south:      28:06N                 west:       72E                 east:
>>>>>       77:24E                 nsres:      0:54                 ewres:
>>>>>  5:24                 rows:       1                 cols:       1
>>>>>       cells:      1*
>>>>> Also, can you tell me which method will be more suitable for my final
>>>>> goal?
>>>>> Thanks & Regards,
>>>>> Bharath
>>>>> *Disclaimer: *This email and any files transmitted with it are
>>>>> confidential and intended solely for the use of the individual or entity to
>>>>> whom they are addressed. If you have received this email in error please
>>>>> notify the system manager. This message contains confidential information
>>>>> and is intended only for the individual named. If you are not the named
>>>>> addressee you should not disseminate, distribute or copy this e-mail.
>>>>> Please notify the sender immediately by e-mail if you have received this
>>>>> e-mail by mistake and delete this e-mail from your system. If you are not
>>>>> the intended recipient you are notified that disclosing, copying,
>>>>> distributing or taking any action in reliance on the contents of this
>>>>> information is strictly prohibited.
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201124/04926959/attachment-0001.html>
