[GRASS-user] tiled version for r.neighbors
Moritz Lennert
mlennert at club.worldonline.be
Wed Oct 7 04:08:14 PDT 2020
On 7/10/20 12:37, Bernardo Santos wrote:
> Dear community,
> I have recently found that some functions such as r.mapcalc and
> r.textile have their "tiled" versions, whichi is perfect for processing
> things in large extents and fine scale resolution.
> I need to perform a moving window analysis, such as using r.neighbors,
> over large areas. Is there already any implementation of a
> "r.neighbors.tiled" or something like that?
> (If not, that would definitely be very useful!)
AFAIK, there is no r.neighbors.tiled. Actually, the two others you cite
were quick hacks from me which I decided to make available in case they
could be useful.
Several tests by others using r.mapcalc.tiled have not shown significant
speed increase, and so there is currently a discussion about how to
solve this (the current idea is to try with r.patch instead of the
internal python-based patching routine). Unfortunately, I don't have
much time for GRASS GIS these days, so will not be able to do anything
about this.
You could have a look at the existing *.tiled modules (see link to the
code at the bottom of the online man page) to see how they work (not
very complicated) and try to cook your own for r.neighbors. :-)
Moritz
