[GRASS-user] Error with GRASS 7.8.3
Thomas Adams tea3rd at gmail.com
Fri Oct 9 12:17:33 PDT 2020
Hi all:
I have had these 2 problems for a while, but tried to work around them...
It may be with my build from source...
PROBLEM #1...
When I try to create a new LOCATION and MAPSET (just a simple lat-long
LOCATION over the CONUS), I use the GUI to select the projection and datum
(lat-long & WGS84)... I get something like this:
Starting GRASS GIS...
  File "/usr/local/grass78/gui/wxpython/location_wizard/wizard.py", line
1080, in OnPageChanging
    self.parent.parent, transforms=ret)
  File "/usr/local/grass78/gui/wxpython/location_wizard/dialogs.py", line
617, in __init__
    transforms = '---\n\n0\nDo not apply any datum transformations\n\n' +
transforms
TypeError: must be str, not bytes
617, in __init__
transforms
Exit was requested in GUI.
GRASS GIS will not start. Bye.
PROBLEM #2...
when I attempt to re-project a RASTER between LOCATIONS, I get no errors,
but all the raster values are NULL, even with the target LOCATION defined
large enough. And sometimes, it works!
r.proj will report something like this:
Output:
Cols: 1 (original: 5390)
Rows: 1 (original: 3288)
North: 4762.500000 (original: 1985962.500000)
South: 0.000000 (original: -13673137.500000)
West: -4762.500000 (original: -11820525.000000)
East: 0.000000 (original: 13849350.000000)
EW-res: 4762.500000
NS-res: 4762.500000
The original raster is perfectly fine. Any initial thoughts?
Best,
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201009/9fd5b284/attachment.html>
