[GRASS-user] r.in.gdal problem
Moritz Lennert
mlennert at club.worldonline.be
Tue Oct 13 01:19:44 PDT 2020
On 12/10/20 20:42, chadli Kadri wrote:
> Hi;
> I am working on grass-gis 7.8 under windows 10 (python 3.7),
> when I run my python script on grass-shell this error message appears:
> *Unable to open datasource*
> *<LC08_L1TP_197037_20190620_20190704_01_T1_B1.TIF>*
This is the actual error. Are you sure that this file exists in the
directory you are running this script in ? It might be better to provide
the complete path to the file.
Moritz
> *Traceback (most recent call last):*
> *File "E: \ chadli_docs \ Chadli_DISKDUR \ Desertification \ Data \
> SRTM_PROJTED \ Sebal70.py", line 45, in <module>*
> *g.parse_command ('r.in.gdal', input = files [i], output =
> os.path.splitext (files [i]) [0], overwrite = True)*
> *grass.exceptions.CalledModuleError: Module run None r.in.gdal --o input
> = LC08_L1TP_197037_20190620_20190704_01_T1_B1.TIF output =
> LC08_L1TP_197037_20190620_20190704_01_T1_B1 ended with error*
> *Process ended with non-zero return code 1. See errors in the (error)
> output.*
> is there anyone seeing this kind of problem
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
