[GRASS-user] r.param.scale issue
Maris Nartiss
maris.gis at gmail.com
Thu Oct 15 00:42:45 PDT 2020
Hello Vincent,
start with running stress tests on your hardware. I always run at
least 24h memtest followed by several rounds of compiling kernel on
any new hardware. Allowed to catch a misbehaving motherboard of laptop
before I started to use it for my daily needs.
You could try to run process under valgrind to see if anything
suspicious comes up. There should be a warning of use of uninitialized
variable in quant_parse_file function, but it shouldn't affect outcome
in this case (I'll try to commit fix tomorrow).
Happy hunting,
Māris.
ceturtd., 2020. g. 15. okt., plkst. 09:18 — lietotājs Vincent Bain
(<bain at toraval.fr>) rakstīja:
> Hi Markus,
> thank you for your reply and investigation!
> my setup:
> a freshly built GRASS GIS 7.9.dev (64 bit), code revision: 8c2c33b4f
> Debian GNU/Linux 10.5 (buster)
> the whole hardware is 4 months old...
> I had the same issue with several raster source maps.
> Well, for now I go back to r.slope.aspect...
> V.
