[GRASS-user] Classify basins as "narrow"
Ken Mankoff
mankoff at gmail.com
Thu Sep 3 09:27:37 PDT 2020
On 2020-09-02 at 23:59 -07, Moritz Lennert <mlennert at club.worldonline.be> wrote...
> There is also v.voronoi with the -s flag for extraction of skeletons
> from vector polygons.
I have skeletons:
r.to.vect -v input=basins output=basins type=area
v.to.lines input=basins output=bounds
But the voronoi centerline, and then dist from center line to edges, is a much tighter algorithm than the current one (distance from edges -> invert -> stream route -> extract stream as centerline -> dist from center to edges).
Thank you!
-k.
