[GRASS-user] v.patch segmentation fault
Daniel McInerney
daniel.o.mcinerney at gmail.com
Thu Apr 1 02:32:37 PDT 2021
Hi Markus, MarkusM,
many thanks to you both for the quick fix, I tested it now and it's
working perfectly.
best regards,
Daniel.
On 31/03/2021 22:47, Markus Neteler wrote:
> Hi Daniel,
> On Tue, Mar 30, 2021 at 9:57 PM Daniel McInerney
> <daniel.o.mcinerney at gmail.com> wrote:
>> Hi Markus, cc: List,
>> thanks for your reply. I've reproduced the segmentation fault using the
>> roads dataset from the Spearfish dataset. I've split the roads into
>> three separate vector layers, and then patched them together as follows:
>> v.patch -e input=roads_12,roads_interstate output=roads_patch
>> Segmentation fault
> Fixed by Markus Metz in https://github.com/OSGeo/grass/issues/1488 and
> backported to the upcoming GRASS GIS 7.8.6.
> Cheers
> Markus
