[GRASS-user] grass-user Digest, Vol 180, Issue 4
Timothy Glyn Southern tim.southern at talktalk.net
Sat Apr 10 09:43:04 PDT 2021
Problem with wxpython guy in Manjaro with grass 7.8.5
Dear colleagues,
Following a period of low use due to health issues I am once again trying to use GRASS to visualise and analyse archaeological data.
I am running Manjaro and the latest download of GRASS from AUR.
It starts fine and shows both display windows for the GUI and then the windows crash. It is repeatable.
I have tried removing GRASS and reinstalling but that has not fixed the issue. As well I have tried changing the flags on the GUI. None make any difference, as soon as the mouse is apparently moved the windows crash.
Is this a known problem and is there a work around?
Thanks
Tim Southern
Dr Timothy Glyn Southern
0155 941 8432
0791 076 6814
> On 4 Apr 2021, at 20:00, grass-user-request at lists.osgeo.org wrote:
> Send grass-user mailing list submissions to
> 	grass-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
>   1. Re: r.watershed identify inland watershed (ming han)
> Message: 1
> Date: Sat, 3 Apr 2021 16:23:26 -0400
> From: ming han <dustming at gmail.com>
> To: Micha Silver <tsvibar at gmail.com>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] r.watershed identify inland watershed
> Message-ID:
> 	<CAD+uAWjx1XBcc6jk+hau8MnDa7CEAJfWeeEyEWq379efWrpMkw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Micha
>    I understand what you mean. But it requires another step to
> manually identify depressions from these pre-conditioned DEM.
> Cheers
> Ming
> Micha Silver <tsvibar at gmail.com> ?2021?4?3??? ??12:43???
>> On 4/2/21 5:37 PM, ming han wrote:
>>> Maybe I am the only one who has this demand. Following is just a
>>> recommendation to GRASS r.watershed function.
>>> Maybe it is worth having an option to avoid r.watershed overcome
>>> depressions.
>>> The reasons are 1) there are many hydrologically pre condition DEM
>>> data available globally, such as:HydroSHEDS, MERIT
>>>                            2) the depression in these DEM are real
>>> depressions, overcome these depressions will make the entire drainage
>>> system
>> Regarding Hydrosheds, the documentation[1] in section 3.4 explains how
>> they overcame the problem of sinks. They performed a regular "fill
>> sinks" operation on areas that were SRTM artifacts. True natural
>> depressions were identified manually, then another manual procedure of
>> carving rivers was done to force flow thru these depressions and produce
>> hydrologically correct streams and basins. So pre-conditioning to
>> overcome depressions is not a magic bullet...
>> In my opinion, the best results are obtained when true depressions
>> (pits, salt playas or karst regions) are identified, and set to NULL in
>> the elevation raster. That will allow r.watershed to stop routing at
>> those locations, and produce correct stream and basin layers.
>> [1]https://hydrosheds.org/images/inpages/HydroSHEDS_TechDoc_v1_2.pdf
>>> incorrectly.
>>> I understand GRASS has other functions to solve this problem, but just
>>> a user recommendation. I use GRASS a lot.
>>> Thanks
>>> Ming
>>> ming han <dustming at gmail.com <mailto:dustming at gmail.com>>
>>> ?2021?3?30??? ??8:06???
>>>    Got it, thanks everyone~
>>>    Ming
>>>    Micha Silver <tsvibar at gmail.com <mailto:tsvibar at gmail.com>>
>>>    ?2021?3?29??? ??2:40???
>>>        Hello:
>>>        You might try `r.param.scale`, or even better `r.geomorphons`
>>>        modules to
>>>        identify geomorphology features, then filter out all pixels
>>>        identified
>>>        as pits.
>>>        r.watershed is purposely designed to overcome depressions, and
>>>        find flow
>>>        routing thru these spots. So I don't think you can use that
>>>        module to
>>>        identify depressions.
>>>        On 3/27/21 8:49 PM, ming han wrote:
>>>> Hi  Everyone
>>>>     When I do watershed delineation using r.watershed for
>>>        great salt
>>>> lake watershed. I found r.watershed always tried to assign
>>>        an outlet
>>>> for a great salt lake, which does actually not exist because
>>>        it is an
>>>> inland lake and the great salt lake has no watershed outlet
>>>        at all.
>>>>      I noticed that there is a depression option. But is
>>>        there any
>>>> way that  r.watershed can automatically identify depressions
>>>        while
>>>> defining flow accumulation and stream network?
>>>> Thanks
>>>> Ming
>>>> _______________________________________________
>>>> grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>>>        <https://lists.osgeo.org/mailman/listinfo/grass-user>
>>>        Micha Silver
>>>        Ben Gurion Univ.
>>>        Sde Boker, Remote Sensing Lab
>>>        cell: +972-523-665918
>> Micha Silver
>> Ben Gurion Univ.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210403/6b22a457/attachment-0001.html>
> Subject: Digest Footer
> End of grass-user Digest, Vol 180, Issue 4
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210410/b7dd94a8/attachment.html>
