[GRASS-user] Some new issues since installing some Python tools
    Thomas Adams
    tea3rd at gmail.com
    Fri Apr 16 03:13:10 PDT 2021
Thank you, Māris! I'll look into these...
Best regards,
Tom
On Fri, Apr 16, 2021 at 2:00 AM Maris Nartiss <maris.gis at gmail.com> wrote:
> Recompiling GRASS will not help. Look at your environment settings. In
> terminal examine output of env – most likely it contains some extra
> python paths that should not be there.
> Usual suspects of not playing nice are any python modules directly
> (ctypes, SWIG, ...) utilizing code from external compiled libraries
> (GDAL, wxWidgets, PROJ, ...). Make sure you are using only one python
> and its modules linking to other shared libraries are compiled with
> the same version of shared library. On Ubuntu package manager takes
> care of those aspects, in a virtual or mixed environment you are on
> your own.
> Good luck,
> Māris.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210416/56d91a6b/attachment.html>
