[GRASS-user] Some new issues since installing some Python tools
Maris Nartiss
maris.gis at gmail.com
Sun Apr 18 22:48:32 PDT 2021
Hello Tom,
please in a few words describe the issue and the solution you found.
This will help others facing same error message to find solution by
simple googling.
Good to hear that you are back on a horse,
Māris.
2021-04-16 13:57 GMT+03:00, Thomas Adams <tea3rd at gmail.com>:
> Hi Māris!
> I found the issue -- life is good again! Thank you so much!
> Best regards,
> Tom
> On Fri, Apr 16, 2021 at 2:00 AM Maris Nartiss <maris.gis at gmail.com> wrote:
>> Recompiling GRASS will not help. Look at your environment settings. In
>> terminal examine output of env – most likely it contains some extra
>> python paths that should not be there.
>> Usual suspects of not playing nice are any python modules directly
>> (ctypes, SWIG, ...) utilizing code from external compiled libraries
>> (GDAL, wxWidgets, PROJ, ...). Make sure you are using only one python
>> and its modules linking to other shared libraries are compiled with
>> the same version of shared library. On Ubuntu package manager takes
>> care of those aspects, in a virtual or mixed environment you are on
>> your own.
>> Good luck,
>> Māris.
