[GRASS-user] Problems using v.surf.idw
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Apr 20 23:47:04 PDT 2021
Dear all,
I opened a new issue with a simple example:
https://github.com/OSGeo/grass/issues/1547
Thank you for the replies.
Luís
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Monday, April 19, 2021 4:53 PM, Anna Petrášová <kratochanna at gmail.com> wrote:
> On Mon, Apr 19, 2021 at 10:24 AM Veronica Andreo <veroandreo at gmail.com> wrote:
>> [bringing the issue back to the list for reference]
>> Dear Luis,
>> Thanks for your feedback!
>> If you didn't provide a column name, and the module didn't fall back to the cat column as it is supposed to, please report it as a bug (ideally with a reproducible example). According to the manual and my very little understanding of the c code, it should.
> Vero is right, I tested it and it does work as the manual describes, using the values of categories in your case.
> Anna
>> All the best,
>> Vero
>> El lun, 19 abr 2021 a las 16:00, Luís Moreira de Sousa (<luis.de.sousa at protonmail.ch>) escribió:
>>> Hi Vero,
>>> from what I understand the module is seeking neither the value column, not the cat column. This map was created with r.to.vect, these are its attributes:
>>>> v.info -c soil_map_rcl_no_water
>>> Displaying column types/names for database connection of layer <1>:
>>> INTEGER|cat
>>> INTEGER|value
>>> CHARACTER|label
>>> If v.surf.idw was indeed seeking the cat column I would expect the module to succeed with this input, producing a nice Voronoi map.
>>> My suggestion would be to explicitly reference the name of the default column/attribute in the manual.
>>> Thank you.
>>> Luís
>>> On Monday, April 19, 2021 1:56 PM, Veronica Andreo <veroandreo at gmail.com> wrote:
>>>> Dear Luis,
>>>> El lun, 19 abr 2021 a las 8:45, Luís Moreira de Sousa via grass-user (<grass-user at lists.osgeo.org>) escribió:
>>>>> Dear Anna,
>>>>> thank you for the reply, indeed once I added the column parameter the module completed successfully. The manual includes the following on this parameter:
>>>>> column=name
>>>>> Name of attribute column with values to interpolate
>>>>> If not given and input is 2D vector map then category values are used. If input is 3D vector
>>>>> map then z-coordinates are used.
>>>>> If I read that correctly, the module should pick up the "value" column by defualt. This particular layer was created by GRASS itself and includes a "value" column:
>>>> I might be biased, but the description is clear to me: provide the name of a column that contains the values/quantities that will be used to interpolate. If you do not provide a column name, cat will be used (i.e., the IDs) in a 2D vector, or the z column in a 3D vector.
>>>>> INTEGER|cat
>>>>> INTEGER|value
>>>>> CHARACTER|label
>>>>> It is now clear this is not the case, `v.surf.idw` is seeking another column by default, one that is not created by vector creating modules.
>>>> It does not seek for another column, it defaults to cat if you do not provide a column name where the variable you want to interpolate is. It would be annoying, IMO, if I was forced to name a column `value` just because a module only takes that name. Also, there might be many columns with quantities/values in the attr table of a vector. How is the module supposed to know which one to use, if the user does not provide a name?
>>>>> Perhaps this could be made more explicit in the manual page.
>>>> Maybe the fact that value appears in the description and your column is called value triggered the confusion?
>>>> We really appreciate any suggestions on how to improve the wording to make it clearer.
>>>> Best,
>>>> Vero
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210421/4364ec05/attachment.html>
