[GRASS-user] wxpython and wxgtk c++ abi mismatch error - how to fix?
Maximilian Stahlberg maximilian.stahlberg at tu-berlin.de
Tue Aug 3 02:18:39 PDT 2021
from what you describe I had the same problem and was able to fix it. I
believe the issue is that wxpython 4.0.7.2 is outdated as the
maintainer never got a more recent version to build. However, you can
obtain version 4.1.1 for your current user via pip:
pip install --user --update wxpython
This should allow the GUI to run with no warnings or crashes.
Best,
Max
On Mon, 2021-08-02 at 13:23 -0700, Donovan Cameron wrote:
> My system info:
> OS: Arch Linux
> GRASS: 7.8.5
> wxgtk3: 3.0.5.1
> python-wxpython: 1:4.0.7.2
> To compile GRASS I have python-wxpython set as a dependency and it
> builds fine but I always get this warning on startup of GRASS:
> > % grass78 --gui
> > Starting GRASS GIS...
> > 12:54:21: Warning: Mismatch between the program and library build
> > versions detected.
> > The library used 3.0 (wchar_t,compiler with C++ ABI 1014,wx
> > containers,compatible with 2.8),
> > and wxPython used 3.0 (wchar_t,compiler with C++ ABI 1016,wx
> > containers,compatible with 2.8).
> Recently, the GUI started to crash without any error or warning. It
> launches a location/project and as soon as the two windows load (map
> and layer windows) they just crash after a few seconds. No output in
> terminal to indicate the cause. Can still execute command line GRASS
> no problem though, so it doesn't crash the entire program just the
> GUI.
> I've never really understood what causes the warning and now this
> crash - do I need to re-compile wxgtk3[1] and python-wxpython[2] to
> fix it? They do take a little bit of time to compile so curious if
> anyone has encountered this as well and has some insight before I
> dive in!
> I'm thinking the error is because the compiler used has some
> differences to it as seen from C++ ABI 1014 and 1016.
> The wxgtk package in Arch Linux has a 6 year old patch[3] applied
> that has that exact warning in it and the comment for the patch in
> the PKGBUILD is:
> > # C++ ABI check is too strict and breaks with GCC 5.1
> > # https://bugzilla.redhat.com/show_bug.cgi?id=1200611
> Thanks,
> Donovan (saultdon)
> [1]
> https://github.com/archlinux/svntogit-packages/blob/packages/wxgtk/trunk/PKGBUILD
> [2]
> https://github.com/archlinux/svntogit-community/blob/packages/python-wxpython/trunk/PKGBUILD
> [3]
> https://github.com/archlinux/svntogit-packages/blob/packages/wxgtk/trunk/make-abicheck-non-fatal.patch
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
