[GRASS-user] v.external, postgis materialized views and projection
    Donovan Cameron
    sault.don at gmail.com
    Mon Aug 16 22:05:55 PDT 2021
On 2021-08-16 12:18 p.m., Phillip Allen wrote:
> I am not sure about GRASS's quirks in respect to this problem but I do
> see in QGIS that in my views I often have to specifically CAST my
> geometries so QGIS can see the Z & M values:
> example: SELECT b. sample_id, b. au_ppm, b. as_ppm, b. cu_ppm,
> ST_TRANSFORM(b.geom, 32718 )::geometry(LineStringZM,32718) FROM
> bore_hole b;
Tested on a new set of polygons and casted but it didn't make a
difference. GRASS doesn't like ST_Transform on materialized views it
looks like.
All the views are opening in QGIS fine and with their correct projection
and geometry type (with and without casting to a specific type).
> On Mon, Aug 16, 2021 at 1:10 PM Saulteau Don <sault.don at gmail.com
> <mailto:sault.don at gmail.com>> wrote:
>     When I use v.external to load a postgis materialized view it says
>     the projection mismatches the Location but they are actually the same.
>         % v.external input="PG:host=localhost dbname=database"
>         layer=table_1 output=t
>         ERROR: Projection of dataset does not appear to match current
>         location.
>           Location PROJ_INFO is:
>           name: NAD83 / UTM zone 10N
>           datum: nad83
>           ellps: grs80
>           proj: utm
>           zone: 10
>           no_defs: defined
>           init: EPSG:26910
>           Dataset PROJ_INFO is:
>           name: NAD83 / BC Albers
>           datum: nad83
>           ellps: grs80
>           proj: aea
>           lat_0: 45
>           lon_0: -126
>           lat_1: 50
>           lat_2: 58.5
>           x_0: 1000000
>           y_0: 0
>           no_defs: defined
>           Difference in: proj
>           In case of no significant differences in the projection
>     definitions,
>           use the -o flag to ignore them and use current location
>     definition.
>           Consider generating a new location from the input dataset
>     using the
>           'location' parameter.
>     It looks like GRASS sees the projection from the source table used
>     for the materialized view instead of the materialized views
>     projection that was set in postgis using ST_Transform().
>     Is this normal for grass to see materialized views like this?
>     Donovan
>     _______________________________________________
>     grass-user mailing list
>     grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>     https://lists.osgeo.org/mailman/listinfo/grass-user
>     <https://lists.osgeo.org/mailman/listinfo/grass-user>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210816/722c4a4f/attachment-0001.html>
