[GRASS-user] Error import from grass.pygrass.vector library
Manuele Pesenti manuele.pesenti at gter.it
Fri Aug 20 07:40:22 PDT 2021
Dear All,
I'm moving my first steps on the development of a python script that uses Grass, but I cannot import from the grass.pygrass.vector library.
I work on a Ubuntu/Linux environment and I've installed grass using apt, this is the test script I'm currently running:
# -*- coding: utf-8 -*-
import os, sys
GISBASE = '/usr/lib/grass78'
GRASSBIN = '/usr/bin/grass78'
# Define GRASS-Python environment
os.environ['GISBASE'] = GISBASE
os.environ['GRASSBIN'] = GRASSBIN
sys.path.append(os.path.join(GISBASE, "etc", "python"))
from grass_session import Session
import grass.script as gs
print(f"LD_LIBRARY_PATH: {os.environ['LD_LIBRARY_PATH']}")
print(f"GRASSBIN: {os.environ['GRASSBIN']}")
from grass.pygrass.vector import Vector
print('DONE!')
and this is the output:
$ python import_test.py
LD_LIBRARY_PATH: /usr/lib/grass78/lib
GRASSBIN: /usr/bin/grass78
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 76, in load
    return ctypes.cdll.LoadLibrary(path)
  File "/usr/lib/python3.9/ctypes/__init__.py", line 452, in LoadLibrary
    return self._dlltype(name)
  File "/usr/lib/python3.9/ctypes/__init__.py", line 374, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
  File "/home/manuele/Lavoro/ETS/ETSCore/scripts/import_test.py", line 21, in <module>
  File "/usr/lib/grass78/etc/python/grass/pygrass/vector/__init__.py", line 5, in <module>
    import grass.lib.gis as libgis
  File "/usr/lib/grass78/etc/python/grass/lib/gis.py", line 23, in <module>
    _libs["grass_gis.7.8"] = load_library("grass_gis.7.8")
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 62, in load_library
    return self.load(path)
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 78, in load
    raise ImportError(e)
ImportError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
Thank you very mutch for any help
Cheers
      Manuele
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210820/a0013c06/attachment.html>
