[GRASS-user] Error import from grass.pygrass.vector library
    Stefan Blumentrath
    Stefan.Blumentrath at nina.no
    Tue Aug 24 01:10:10 PDT 2021
Hm...
Did you initialize the session, e.g. like:
with Session(gisdb="/tmp", location="location", create_opts="EPSG:4326"):
    from grass.pygrass.vector import Vector
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Manuele Pesenti
Sent: tirsdag 24. august 2021 09:38
To: Grass User <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Error import from grass.pygrass.vector library
Drear Stefan,
thanks for your quick reply but the solution is not so clear, I already use grass_session library even if not reported in the attached example, how can it helps with the issue? Just import the vector library after the session is loaded does not solve as far as I've tested.
Cheers
    Manuele
---- Attivato ven, 20 ago 2021 21:26:22 +0200 Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> ha scritto ----
Dear Manuele,
For ctypes in pygrass, the C-libraries need to be loaded explicitly.
You could have a look here:
https://github.com/zarch/grass-session/blob/6097f834be20ee0d703deb2af90f22d6dc66f368/grass_session/session.py#L332<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fzarch%2Fgrass-session%2Fblob%2F6097f834be20ee0d703deb2af90f22d6dc66f368%2Fgrass_session%2Fsession.py%23L332&data=04%7C01%7C%7C5490515dd62a4bc57acf08d966d433e6%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637653884462405890%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=V0ecwomhbdvobU2B3tal1udBRXj5jkvWwN9e4K0dKSw%3D&reserved=0>
to see how it can be done, or just use the grass_session python library (pip install grass-session) for convenience...
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>> On Behalf Of Manuele Pesenti
Sent: fredag 20. august 2021 16:40
To: grass-user <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: [GRASS-user] Error import from grass.pygrass.vector library
Dear All,
I'm moving my first steps on the development of a python script that uses Grass, but I cannot import from the grass.pygrass.vector library.
I work on a Ubuntu/Linux environment and I've installed grass using apt, this is the test script I'm currently running:
# -*- coding: utf-8 -*-
import os, sys
GISBASE = '/usr/lib/grass78'
GRASSBIN = '/usr/bin/grass78'
# Define GRASS-Python environment
os.environ['GISBASE'] = GISBASE
os.environ['GRASSBIN'] = GRASSBIN
sys.path.append(os.path.join(GISBASE, "etc", "python"))
from grass_session import Session
import grass.script as gs
print(f"LD_LIBRARY_PATH: {os.environ['LD_LIBRARY_PATH']}")
print(f"GRASSBIN: {os.environ['GRASSBIN']}")
print('DONE!')
and this is the output:
$ python import_test.py
LD_LIBRARY_PATH: /usr/lib/grass78/lib
GRASSBIN: /usr/bin/grass78
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 76, in load
    return ctypes.cdll.LoadLibrary(path)
  File "/usr/lib/python3.9/ctypes/__init__.py", line 452, in LoadLibrary
    return self._dlltype(name)
  File "/usr/lib/python3.9/ctypes/__init__.py", line 374, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
  File "/home/manuele/Lavoro/ETS/ETSCore/scripts/import_test.py", line 21, in <module>
  File "/usr/lib/grass78/etc/python/grass/pygrass/vector/__init__.py", line 5, in <module>
    import grass.lib.gis as libgis
  File "/usr/lib/grass78/etc/python/grass/lib/gis.py", line 23, in <module>
    _libs["grass_gis.7.8"] = load_library("grass_gis.7.8")
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 62, in load_library
    return self.load(path)
  File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 78, in load
    raise ImportError(e)
ImportError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
Thank you very mutch for any help
Cheers
      Manuele
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210824/ec3258b0/attachment-0001.html>
