[GRASS-user] Error import from grass.pygrass.vector library
Stefan Blumentrath
Stefan.Blumentrath at nina.no
Tue Aug 24 02:04:44 PDT 2021
What version of grass_sessions do you use?
I run grass_session 0.4 on Ubuntu 18.04 with GRASS 7.8 and your script works fine...
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Manuele Pesenti
Sent: tirsdag 24. august 2021 10:53
To: Grass User <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Error import from grass.pygrass.vector library
---- Attivato mar, 24 ago 2021 10:10:10 +0200 Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> ha scritto ----
Hm...
Did you initialize the session, e.g. like:
with Session(gisdb="/tmp", location="location", create_opts="EPSG:4326"):
from grass.pygrass.vector import Vector
Yes it's exactly what I do, the strange fact is that I can by-pass the exception assigning the LD_LIBRARY_PATH value before running the script even if even now before importing vector lib this env variable has the correct value exactly thanks to the grass_session lib import...
so the script modified as you suggested reported here under still raise the exception
# -*- coding: utf-8 -*-
import os, sys
GISBASE = '/usr/lib/grass78'
GRASSBIN = '/usr/bin/grass78'
# Define GRASS-Python environment
os.environ['GISBASE'] = GISBASE
os.environ['GRASSBIN'] = GRASSBIN
sys.path.append(os.path.join(GISBASE, "etc", "python"))
from grass_session import Session
import grass.script as gs
print(f"LD_LIBRARY_PATH: {os.environ['LD_LIBRARY_PATH']}")
print(f"GRASSBIN: {os.environ['GRASSBIN']}")
print('DONE!')
while the old script (for convenience reported here under) runned as
$ LD_LIBRARY_PATH=$(grass78 --config path)/lib python import_test.py
LD_LIBRARY_PATH: /usr/lib/grass78/lib
GRASSBIN: /usr/bin/grass78
DONE!
returns just what printed in the script without raising the exception.
import os, sys
# from grass_session import Session
# with Session(gisdb="/tmp", location="location", create_opts="EPSG:4326"):
print('DONE!')
Cheers
Manuele
Cheers
Stefan
From: grass-user <grass-user-bounces at lists.osgeo.org<mailto:grass-user-bounces at lists.osgeo.org>> On Behalf Of Manuele Pesenti
Sent: tirsdag 24. august 2021 09:38
To: Grass User <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Drear Stefan,
thanks for your quick reply but the solution is not so clear, I already use grass_session library even if not reported in the attached example, how can it helps with the issue? Just import the vector library after the session is loaded does not solve as far as I've tested.
Cheers
Manuele
---- Attivato ven, 20 ago 2021 21:26:22 +0200 Stefan Blumentrath <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>> ha scritto ----
Dear Manuele,
For ctypes in pygrass, the C-libraries need to be loaded explicitly.
You could have a look here:
https://github.com/zarch/grass-session/blob/6097f834be20ee0d703deb2af90f22d6dc66f368/grass_session/session.py#L332<https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2Fzarch%2Fgrass-session%2Fblob%2F6097f834be20ee0d703deb2af90f22d6dc66f368%2Fgrass_session%2Fsession.py%23L332&data=04%7C01%7C%7C787f11b2fc5246a7da6d08d966dc9ee5%7C6cef373021314901831055b3abf02c73%7C0%7C0%7C637653920686707703%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C2000&sdata=XA2vZhGMasSyLFE3KRrBPaXUjewtp2MNBzA4Dwfre9g%3D&reserved=0>
to see how it can be done, or just use the grass_session python library (pip install grass-session) for convenience...
Cheers
Stefan
Sent: fredag 20. august 2021 16:40
To: grass-user <grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>>
Subject: [GRASS-user] Error import from grass.pygrass.vector library
Dear All,
I'm moving my first steps on the development of a python script that uses Grass, but I cannot import from the grass.pygrass.vector library.
I work on a Ubuntu/Linux environment and I've installed grass using apt, this is the test script I'm currently running:
import os, sys
print('DONE!')
and this is the output:
$ python import_test.py
File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 76, in load
return ctypes.cdll.LoadLibrary(path)
File "/usr/lib/python3.9/ctypes/__init__.py", line 452, in LoadLibrary
return self._dlltype(name)
File "/usr/lib/python3.9/ctypes/__init__.py", line 374, in __init__
self._handle = _dlopen(self._name, mode)
OSError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
During handling of the above exception, another exception occurred:
File "/home/manuele/Lavoro/ETS/ETSCore/scripts/import_test.py", line 21, in <module>
File "/usr/lib/grass78/etc/python/grass/pygrass/vector/__init__.py", line 5, in <module>
import grass.lib.gis as libgis
File "/usr/lib/grass78/etc/python/grass/lib/gis.py", line 23, in <module>
_libs["grass_gis.7.8"] = load_library("grass_gis.7.8")
File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 62, in load_library
return self.load(path)
File "/usr/lib/grass78/etc/python/grass/lib/ctypes_loader.py", line 78, in load
raise ImportError(e)
ImportError: libgrass_datetime.7.8.so: cannot open shared object file: No such file or directory
Thank you very mutch for any help
Cheers
Manuele
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210824/1099f5d5/attachment-0001.html>
