[GRASS-user] error when importing soil grids data into GRASS
Veronica Andreo
veroandreo at gmail.com
Wed Dec 8 04:15:59 PST 2021
Hi Laura,
Great! Much appreciated :)
Vero
El mié, 8 dic 2021 a las 7:31, Laura Poggio (<laura.poggio at gmail.com>)
escribió:
> Hi Veronica,
> thanks for pointing this out. The projection should be defined in the VRTs
> of Soilgrids 2.0 and normally it should be recognised in GRASS-GIS. I have
> been using the same files you mentioned. We will look into the issue and
> let you know.
> Thanks
> Laura
> On Wed, 8 Dec 2021 at 01:31, Veronica Andreo <veroandreo at gmail.com> wrote:
>> Hi Markus,
>> thanks for your answer :)
>> El mar., 7 dic. 2021 14:43, Markus Neteler <neteler at osgeo.org> escribió:
>>> Hi Vero,
>>> On Tue, Dec 7, 2021 at 6:12 PM Veronica Andreo <veroandreo at gmail.com>
>>> wrote:
>>> > Dear all,
>>> > I'm trying to import soil grids data for south america into grass gis
>>> by means of r.import and the vsicurl driver and I'm facing different errors
>>> according to the soilgrid version I use. See below:
>>> > Fist attempt:
>>> > gdalinfo /vsicurl/
>>> https://files.isric.org/soilgrids/latest/data/ocd/ocd_0-5cm_mean.vrt
>>> > Driver: VRT/Virtual Raster
>>> > Files: /vsicurl/
>>> > /vsicurl/
>>> https://files.isric.org/soilgrids/latest/data/ocd/ocd_0-5cm_mean.vrt.ovr
>>> > /vsicurl/
>>> https://files.isric.org/soilgrids/latest/data/ocd/./ocd_0-5cm_mean/tileSG-018-027/tileSG-018-027_2-4.tif
>>> > /vsicurl/
>>> https://files.isric.org/soilgrids/latest/data/ocd/./ocd_0-5cm_mean/tileSG-018-027/tileSG-018-027_1-1.tif
>>> > Size is 159246, 58034
>>> > Coordinate System is:
>>> > PROJCRS["Interrupted_Goode_Homolosine",
>>> This is the problem.
>> Any idea why it's not recognized? I see it is in PROJ and as you show
>> gdalwarp works. Is it something GRASS related?
>> Here my workaround:
>>> ### ocd
>>> # PROJCRS["Interrupted_Goode_Homolosine" ... :-(
>>> # requires a trick - r.import still fails
>>> eval `g.region -g`
>>> gdalwarp -t_srs epsg:4326 -te $w $s $e $n ocd/ocd_0-5cm_mean.vrt
>>> ocd_0_5cm_mean_epsg4326.tif -co COMPRESS=LZW
>> Anyway replacing ocd/ocd_0-5cm_mean.vrt by /vsicurl/
>> https://files.isric.org/soilgrids/latest/data/ocd/ocd_0-5cm_mean.vrt in
>> your workaround does the trick, takes a while, but does it. Thanks a LOT
>> for the hint!!
>> @Luís Moreira de Sousa <luis.de.sousa at protonmail.ch> would it be
>> possible to provide the version 2.0 with the projection defined? Or
>> additionally in the easy to use epsg 4326 as an alternative for lazy people
>> like me? :)
>> Vero
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211208/1d9d7fa3/attachment-0001.html>
