[GRASS-user] Grass Graphic Model v.net.distance Not Accepting point layer in From or To fields
Joshua Geoghegan joshua.geoghegan at mornpen.vic.gov.au
Wed Dec 29 18:52:16 PST 2021
Happy holidays all.
Just wondering if you were able to help with the below when you have a chance. I'm hoping to have it working in the new year.
Regards,
Josh
[MPS]
Joshua Geoghegan | GIS Specialist
Email: joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>
Phone: 03 5950 1321
Private Bag 1000, Rosebud VIC 3939 | 90 Besgrove Street, Rosebud VIC 3939
Follow us on social media!      [mornpen.vic.gov.au] <https://www.mornpen.vic.gov.au>  [Facebook] <https://www.facebook.com/mornpenshire>  [Instagram] <https://www.instagram.com/ourpeninsula/>  [Twitter] <http://twitter.com/MornPenShire>
[Latest News]<https://www.mornpen.vic.gov.au/emailcampaign>
Mornington Peninsula Shire acknowledges and pays respect to the Bunurong/Boon Wurrung people,
the traditional custodians of these lands and waters.
We are committed to carbon neutrality.
From: grass-user <grass-user-bounces at lists.osgeo.org> on behalf of Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au>
Sent: Wednesday, 8 December 2021 9:47 AM
To: Moritz Lennert <mlennert at club.worldonline.be>; grass-user at lists.osgeo.org <grass-user at lists.osgeo.org>
Subject: Re: [GRASS-user] Grass Graphic Model v.net.distance Not Accepting point layer in From or To fields
Hi Moritz,
Regarding the last comment in your reply, with everything I have tried so far when I change the From and To layers to 2 it will always reverts back to layer 1 when I come back in to this form.
Also, when I change it to layer 2 and try to add a where clause I am told there is no layer linked to layer 2.
[cid:image009.png at 01D7EC17.A1ACFA70]
I’ve connected the points table to the network here.
[cid:image010.png at 01D7EC17.A1ACFA70]
Below is the setup for the command. I couldn’t seem to output the script into text so here is that function in the Python output. Notice the layer is set to 1. I keep changing that to 2 also but it reverts to 1.
    run_command("v.db.connect",
                flags='o',
                overwrite = True,
                map="myroads_net_Rosebud_Meals",
                driver="sqlite",
                database="$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db",
                table="Meals_Rosebud_reproj",
                key="cat",
                layer="1",
                separator="pipe")
Regards,
[MPS]
JOSHUA GEOGHEGAN | GIS Specialist
Phone: 03 5950 1321
[mornpen.vic.gov.au]<https://www.mornpen.vic.gov.au/>[Facebook]<https://www.facebook.com/mornpenshire>[Instagram]<https://www.instagram.com/ourpeninsula/>[Twitter]<http://twitter.com/MornPenShire>
the Traditional Custodians of these lands and waters.
Sent: Wednesday, 8 December 2021 8:32 AM
Subject: RE: [GRASS-user] Grass Graphic Model v.net.distance Not Accepting point layer in From or To fields
Apologies, I’ll take a look today.
Regards,
[MPS]
Phone: 03 5950 1321
From: Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>>
Sent: Tuesday, 7 December 2021 6:16 PM
To: Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>>; grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
Hi Josh,
I sent you a reply:
https://lists.osgeo.org/pipermail/grass-user/2021-December/082742.html
I don't think you sent anything since then.
Moritz
Le 5 décembre 2021 21:50:54 GMT+00:00, Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>> a écrit :
Hi Moritz,
I was wondering if you got a chance to see my reply with my current Grass workflow.
Hope it makes sense.
Regards,
Phone: 03 5950 1321
Sent: Friday, 26 November 2021 1:57 PM
To: Moritz Lennert <mlennert at club.worldonline.be<mailto:mlennert at club.worldonline.be>>; grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>
Hi Moritz,
Does the below make sense?
Perhaps I have connected the point and line vectors incorrectly?
Regards,
Josh
Phone: 03 5950 1321
Sent: Wednesday, 24 November 2021 10:24 AM
Hi Moritz,
When I set it to layer 2 (which is the point layer I connected) and close the v.net.distance dialog, and reopen it I see the form reload and it switches back to 1.
I also try to create the where clause and now it says no table linked to layer 2 even though I linked it with v.db.connect.
I tried connecting the attribute table to the same vector for the points, as well as trying connecting to the linked point/network vector.
Am I missing a step perhaps? Is the attribute table coming straight from the shapefile I am importing?
Below are the steps up until v.net.distance, with my network being cleaned up beforehand.
The highlighted section is where I import the points up until the v.net.distance.
I probably don’t need the v.db.addtable. That was there so I could populate the distance for each route but I guess v.net.distance outputs that.
It still didn’t work when I removed that.
Hopefully that makes sense.
Regards,
JOSHUA GEOGHEGAN | GIS Specialist | MORNINGTON PENINSULA SHIRE
Phone: 03 5950 1321
www.mornpen.vic.gov.au<http://www.mornpen.vic.gov.au> | Twitter @MornPenShire | Facebook @MornPenShire
-----Original Message-----
Sent: Tuesday, 23 November 2021 6:07 PM
Hi Joshua,
Le 23 novembre 2021 01:45:14 GMT+01:00, Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>> a écrit :
>Thanks Moritz,
>What would be the reason behind the point layer switching back to layer 1 in v.net.distance if I have linked the point and network?
>I'll test your two options in the meantime, but it still switches back to layer 1.
I'm not sure I understand what you mean by "switching back". Most modules have layer=1as the default setting. That doesn't mean that the specific layer you work on does not have other layers. Have you checked whether you can set it to layer=2 ?
To help you, we would need some more info:
- What is the exact command you use to connect the lines and the points ?
- What is the output of v.category with option=report on the resulting file ?
Moritz
>[cid:image001.png at 01D7E05F.93540130]
>Regards,
>Phone: 03 5950 1321
>Sent: Monday, 22 November 2021 6:32 PM
>To: grass-user at lists.osgeo.org<mailto:grass-user at lists.osgeo.org>; Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au>>
>Hi Joshua,
>Le 21 novembre 2021 22:12:42 GMT+01:00, Joshua Geoghegan <joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au<mailto:joshua.geoghegan at mornpen.vic.gov.au%3cmailto:joshua.geoghegan at mornpen.vic.gov.au>>> a écrit :
>>Hi there,
>>I have been stuck on a problem and I was hoping you could help, as I had no luck on GIS Stack Exchange.
>>I have a point and network layer connected in Grass GIS via the graphic modeler.
>What exactly do you mean by 'the graphic modeler'. I assume you connect the two using v.net ?
>> I am trying to find the shortest path between the first point (ROUND=0) and every other point (ROUND != 0) on the same point layer. For some reason I can select this layer (layer 2) in both From and To tabs and add category 1-500 (which is more than the number of points), but when I try the where clause and test for values in the ROUND field on the SQL Builder the results show up as '', even though the imported shp file has values. When I hit OK and come back into the form it has reverted back to layer 1 in the From and To tabs, which is road network layer.
>>What could be the issue here?
>As the v.net man page states: "While the arcs created with v.net will retain any attribute information associated with the input vector line/boundary file in data layer 1, nodes created and stored in data layer 2 will not have any associated attribute information."
>You have two options:
>1) Find out what to the category number of the point is that has ROUND=0 and use that as from_cats, and all the others as to_cats.
>This could be done with v.db.select using columns=cat (assuming the column containing the cat values is called 'cat') and where=ROUND=0.
>2) Connect the attribute table of your original point map to the point layer of the connected network map using v.db.connect and the use the from_where and to_where parameters as you did.
>If any of that is not clear, don't hesitate to come back to us.
>Moritz
>DISCLAIMER: This email (and attachments) is for the intended recipient only and may contain privileged, confidential or copyright information. If received in error, please notify sender immediately and delete. Any other use is prohibited. Shire accepts no liability for damage caused by this email (and attachments) due to viruses, corruption, delay, interruption, unauthorised access or use. Views expressed are those of the individual and not necessarily Shire. Shire will only collect personal information from you with your prior consent, use it for the purpose collected or as reasonably expected and not disclose without consent, except if required by law/regulation. For further information see our privacy policy:
>[Arrow] mornpen.vic.gov.au/privacystatement<https://www.mornpen.vic.gov.au/privacystatement>
>[Consider the Environment]
[Arrow]mornpen.vic.gov.au/privacystatement<https://www.mornpen.vic.gov.au/privacystatement>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0001.html>
Type: image/png
Desc: image009.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0004.png>
Type: image/png
Desc: image010.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0005.png>
Type: image/png
Desc: image017.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0006.png>
Type: image/png
Desc: image018.png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0007.png>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0005.gif>
Type: image/gif
Desc: image002.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0006.gif>
Type: image/gif
Desc: image003.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0007.gif>
Type: image/gif
Desc: image004.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0008.gif>
Type: image/gif
Desc: image005.gif
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0009.gif>
Type: image/jpeg
Desc: image006.jpg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211230/54acd5ad/attachment-0001.jpg>
