[GRASS-user] v.rast.stats error: "Unable to seek"
Maris Nartiss maris.gis at gmail.com
Thu Feb 4 01:21:17 PST 2021
Don't want to bring bad news, but it looks more like an offset
overflow. You will not catch it with valgrind. Although it might catch
a bug leading to offset value explosion, most likely the main cause is
just code written for handling of small/medium datasets and not
large/huge ones (=imperfect logic => can't catch that with valgrind).
My suggestion: recompile GRASS with -ftrapv. If it is an integer
overflow, at least it will become clearly obvious.
https://gcc.gnu.org/onlinedocs/gcc/Code-Gen-Options.html
The bad thing is G_fseek calling G_fatal_error without knowing actual
file name (lets put pipes aside) and thus it is impossible to tell
where exactly the error originated from the error message alone.
Better would be to bubble up error to main program and let it deal
with it in a clean way. Of course, as GRASS is designed around current
idioms (handling failure is responsibility of a library making module
development really easy), this will not happen in a foreseeable
future.
One thing you could do – drasticly reduce size of computational region.
Māris.
