[GRASS-user] Error launching GUI in latest verison of trunk
Anna Petrášová kratochanna at gmail.com
Mon Feb 8 07:34:17 PST 2021
Could you create an issue for that? Does this happen with other locations
as well?
On Sun, Feb 7, 2021 at 11:29 PM Eric Patton <eric.r.patton at protonmail.com>
wrote:
> On 21/02/07 10:32PM, Anna Petrášová wrote:
> > Before looking more into this, have you tried make distclean?
> > Anna
> Yes. It also persists with a fresh checkout of grass/master.
> I forgot to mention that just before the GUI crashes, a dialog box pops up
> that
> says "Enable to get the geographic extent. Force quitting wxGUI. Please run
> g.region manually to fix the problem."
> Runing g.region -p prints the following:
> g.region -p
> projection: 99 (unnamed)
> zone:       0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      -383300
> south:      -918400
> west:       -951200
> east:       764600
> nsres:      100
> ewres:      100
> rows:       5351
> cols:       17158
> cells:      91812458
> free(): invalid pointer
> Aborted (core dumped)
> $ g.version -er
> GRASS 7.9.dev (2021)
> libgis revision: 2021-02-08T04:01:23+00:00
> libgis date: 2021-02-07T12:00:00-04:00
> PROJ: 7.0.1
> GDAL/OGR: 3.2.1
> GEOS: 3.9.0
> SQLite: 3.31.1
> $ wx-config --version
> 3.04
> Eric
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210208/b0be403e/attachment.html>
