[GRASS-user] r.futures.potential - unable to open select-cursor
Helmut Kudrnovsky
hellik at web.de
Tue Feb 9 12:33:04 PST 2021
>- set PATH=%PATH%;C:\Program Files\R\R-4.0.3\bin has been included
start winGRASS and type into the console:
C:\>ECHO %PATH%
here in OSGeo4W-winGRASS, it's something like:
C:\OSGEO4~1\apps\grass\grass78\lib;C:\OSGEO4~1\apps\grass\grass78\bin;C:\Users\hkmyr\AppData\Roaming\GRASS7\addons\bin;C:\OSGEO4~1\apps\Python37;C:\OSGEO4~1\apps\Python37\Scripts;{app};C:\OSGEO4~1\apps\Python27\Scripts;C:\OSGEO4~1\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\WBem;C:\OSGEO4~1\apps\msys\bin;C:\Program
Files\R\R-4.0.3\bin\x64;C:\OSGEO4~1\apps\Python37\lib\site-packages\pywin32_system32
post your result here.
>- R libraries have been installed, but when I type in library("MuMIn") in
the terminal, nothing happens
are you're sure you have installed the library systemwide via R in
administrator mode?
just open R (outside any GRASS session) and try to load the library.
what is the result?
here:
> library("MuMIn")
library loaded
then start R within a GRASS session in the console and load the library.
here:
Welcome to GRASS GIS 7.8.5
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt
(C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching <wxpython> GUI in the background, please wait...
Microsoft Windows [Version 10.0.19042.746]
(c) 2020 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>R
R version 4.0.3 (2020-10-10) -- "Bunny-Wunnies Freak Out"
Copyright (C) 2020 The R Foundation for Statistical Computing
Platform: x86_64-w64-mingw32/x64 (64-bit)
R ist freie Software und kommt OHNE JEGLICHE GARANTIE.
Sie sind eingeladen, es unter bestimmten Bedingungen weiter zu verbreiten.
Tippen Sie 'license()' or 'licence()' f├╝r Details dazu.
R ist ein Gemeinschaftsprojekt mit vielen Beitragenden.
Tippen Sie 'contributors()' f├╝r mehr Information und 'citation()',
um zu erfahren, wie R oder R packages in Publikationen zitiert werden
k├Ânnen.
Tippen Sie 'demo()' f├╝r einige Demos, 'help()' f├╝r on-line Hilfe, oder
'help.start()' f├╝r eine HTML Browserschnittstelle zur Hilfe.
Tippen Sie 'q()', um R zu verlassen.
Beim Start - Warnmeldungen:
1: Setting LC_CTYPE=de_AT.cp1252 failed
2: Setting LC_COLLATE=de_AT.cp1252 failed
3: Setting LC_TIME=de_AT.cp1252 failed
4: Setting LC_MONETARY=de_AT.cp1252 failed
> library("MuMIn")
library loaded here also
>- when I run R or Rscript in the terminal the right response is shown, but
only if I run them separately. >If i try to run Rscript after running R in
the terminal, Rscript will not be found. Maybe this is the problem?
tested here:
C:\>R
k├Ânnen.
> q()
Workspace sichern? [y/n/c]: n
C:\>RScript
Usage: /path/to/Rscript [--options] [-e expr [-e expr2 ...] | file] [args]
--options accepted are
--help Print usage and exit
--version Print version and exit
--verbose Print information on progress
--default-packages=list
Where 'list' is a comma-separated set
of package names, or 'NULL'
or options to R, in addition to --no-echo --no-restore, such as
--save Do save workspace at the end of the session
--no-environ Don't read the site and user environment files
--no-site-file Don't read the site-wide Rprofile
--no-init-file Don't read the user R profile
--restore Do restore previously saved objects at startup
--vanilla Combine --no-save, --no-restore, --no-site-file
--no-init-file and --no-environ
'file' may contain spaces but not shell metacharacters
Expressions (one or more '-e <expr>') may be used *instead* of 'file'
See also ?Rscript from within R
within a GRASS session: RScript runs fine after a R session
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
