[GRASS-user] v.surf.idw Not Working
Michaela Lobato amlobat2 at illinois.edu
Fri Feb 12 10:35:05 PST 2021
Hi Markus,
Here is the information:
v.info -c map=coal_test at PERMANENT
INTEGER|cat
INTEGER|cat_
INTEGER|int_1
INTEGER|int_2
DOUBLE PRECISION|dbl_1
DOUBLE PRECISION|dbl_2
DOUBLE PRECISION|dbl_3
DOUBLE PRECISION|dbl_4
DOUBLE PRECISION|dbl_5
Displaying column types/names for database connection of layer <1>:
v.info -t map=coal_test at PERMANENT
nodes=0
points=96
lines=0
boundaries=0
centroids=0
areas=0
islands=0
primitives=96
map3d=0
You can also find the file here
https://github.com/amlobat2/Coal-Test-Shapefile.  Let me know if you need
any additional information.
Best,
Michaela
On Fri, Feb 12, 2021 at 3:29 AM Markus Neteler <neteler at osgeo.org> wrote:
> Hi Michaela,
> On Thu, Feb 11, 2021 at 11:47 PM Michaela Lobato <amlobat2 at illinois.edu>
> wrote:
> > Hello,
> > I have recently been struggling with an issue in GRASS. I am a new GRASS
> user and recently downloaded version 7.8.5 for my MacBook (macOS
> Catalina).  I converted this sample dataset to a shapefile.
> Could you make this shapefile available? Or post the data structure?
> # attribute table  structure
> v.info -c coal_test
> # vector types
> v.info -t coal_test
> Best,
> Markus
A. Michaela Lobato
BS Systems Engineering and Design | Autonomous Systems and Robotics |
December 2019
MS Systems and Entrepreneurial Engineering | Decision and Control | In
Progress
Email: amlobat2 at illinois.edu | Cell: (815) 494-1111
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210212/6487a10b/attachment.html>
