[GRASS-user] Creating a png file with multiple vector maps
Chris Bartolomei surfcjb at yahoo.com
Tue Feb 16 17:30:03 PST 2021
 Ohhhhh !! Sooooooo close ! I can get the two vector maps to overlay and display but no matter what I do I cannot get them to do a color fill ... ugh ... fill_color does nothing. I can use "d.vect map=admin_area color=red" and the boundaries change to red, but "d.vect map=admin_area color=black fill_color=red" and i do not get any filled color. So frustrating. I thought maybe my shapefile imported as just a boundary but when I do a "v.category input=admin_area option=report" I get:Layer/table 1/admin_areatype             count    min    maxpoint                    0        0         0
line                      0        0         0boundary            0        0         0centroid             59       1        25area                     0        0         0face                     0        0         0kernel                  0        0         0all                       59        1        25
Should I have areas in there too ??I wonder if the import went wonky.... what is strange is that the ps.map tool fills the polygons just fine.
Moritz - could please I ask you to do a v.category on one of your vector maps (v.category input=censuslbk_wwake at PERMANENT option=report) and see if it has areas in it or just centroids like I have?
Thanks again for the help!:)
Chris
    On Tuesday, February 16, 2021, 11:20:31 AM EST, Chris Bartolomei <surfcjb at yahoo.com> wrote:
  Well - that does indeed work for you.  I'll try your settings when I get into the office - we're running GRASS on a RHEL 7 cluster - and see what I can come up with.It would be sooo much better if it worked like yours did!Thank you so much for taking the time and testing this out:)v/rChris
    On Tuesday, February 16, 2021, 11:07:10 AM EST, Moritz Lennert <mlennert at club.worldonline.be> wrote:
 On 16/02/21 15:54, Chris Bartolomei wrote:
> Mortiz - are those vector layers areas ? I'm guessing the census is an
> area, the roads are lines and the schools are points, yes?  I'm having
> an issue overlaying two area maps (polygons). i can only get one to show
> ... I have tried your method with all the export GRASS_RENDER* variables
> but I have a country polygon map as the bottom later and a selection of
> a few administrative areas (provinces/states) as the top map and I can
> only get one or the other to show up. It almost seems as if the
> transparency doesn't work and what should be transparent in the admin
> map is actually the background color and blocks the country from being seen.
> Could you please try your method with a couple area (polygon) vector
> maps overlaying each other?
export GRASS_RENDER_IMMEDIATE=png
export GRASS_RENDER_WIDTH=640
export GRASS_RENDER_HEIGHT=480
export GRASS_RENDER_TRUECOLOR=true
export GRASS_RENDER_FILE_COMPRESSION=0
export GRASS_MESSAGE_FORMAT=plain
export GRASS_RENDER_FILE_READ=TRUE
export GRASS_RENDER_FILE=$HOME/test.png
g.region vect=census_wake2000
d.vect map=census_wake2000 at PERMANENT fill_color=grey
d.vect map=censusblk_swwake at PERMANENT fill_color=red
I've tried with
export GRASS_RENDER_TRANSPARENT=TRUE
and
export GRASS_RENDER_TRANSPARENT=FALSE
As you can see in the attached images, the overlay seems to work without
any issues (or I don't understand what you are looking for exactly) and
setting GRASS_RENDER_TRANSPARENT decides on whether the background
should be transparent or not.
A second test in the same data set, but with different layers:
export GRASS_RENDER_FILE=$HOME/test_NC_TRUE.png
g.region vect=boundary_county
d.vect map=boundary_county at PERMANENT
d.vect map=boundary_municp at PERMANENT fill_color=255:255:0:255
export GRASS_RENDER_FILE=$HOME/test_NC_FALSE.png
Again, the overlay works, at least as I would have expected.
Moritz
> On Tuesday, February 16, 2021, 4:19:16 AM EST, Moritz Lennert
> Hi Chris,
> For me, the following works with the current stable GRASS GIS (7.8.5)
> and using maps from the NC demo data set:
> export GRASS_RENDER_TRANSPARENT=true
> d.vect map=census_wake2000 at PERMANENT <mailto:census_wake2000 at PERMANENT>
> fill_color=none
> d.vect map=roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>
> color=255:0:0:255
> d.vect map=schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>
> fill_color=0:128:0:255
> icon=basic/circle size=10
> I attach a small thumbnail of the resulting PNG file.
> Moritz
> On 11/02/21 18:54, Chris Bartolomei via grass-user wrote:
>  > Good morning Anna,
>  > It took quite a while of trial and error but I worked out a method that
>  > kindof works:
>  > First off - unless someone says otherwise, you can't use the PNG driver
>  > (d.mon) method to overlay more than one polygon vector. Sorry - it just
>  > doesn't work. You CAN use the ps.map method - that works really well
>  > generating the image however it by default assumes you are printing on
>  > an A4 piece of paper so there's all sorts of white space.  The image is
>  > centered at the top of this fictional piece of paper. In your postscript
>  > rules file you can use the "maploc" command to position the image
>  > elsewhere on the page. This is necessary because the next trick changes
>  > the paper dimensions but it assumes the origin is the lower left corner
>  > and therefore clips anything that is above the new dimensions. Back to
>  > postscript commands in the rules file first though ... the ps.map maploc
>  > command uses inches (why?? it should be points) so an A4 page is 8.27" x
>  > 11.69" points are 1/72 of an inch thus 595p x 842p - it also has a
>  > default 36p margin (0.5 inch). You'll need those numbers later. maploc
>  > also lets you set the size of your image box:  maploc {x offset from
>  > left edge} {y offset from top} {width of box} {height of box} Note: this
>  > is all done via a BASH script with GRASS 7.4 on Linux (RHEL 7), not
>  > python. This is my postscript rules file:
>  > maploc 0.1 6.815 6.5 4.875 #468p x 351p map box moved down towards the
>  > bottom of the page
>  > # note that if you push it too far down to where the box would run off
>  > the bottom, the image is
>  > # resized to fit on the page so do some testing to come up with the
>  > correct values
>  > # also I found the computational region controls the aspect ratio so
>  > although I say
>  > # 6.5 x 4.875 with the above maploc command, I got a 6.5 x 3.8 inch box.
>  > border y # add a border to the map frame (box)
>  >    color 81:81:81 # shade of gray
>  >    end # end the border controls
>  > vareas admin_area # top vector layer to display
>  >    layer 1 # attribute table to use
>  >    rgbcolumn area_color # name of column holding R:G:B values to fill
>  > the polygons
>  >    color 153:153:153 #boundary color
>  >    end # end the admin_area controls
>  > vareas Country # this is the bottom vectors to display
>  >    color 210:210:210 #boundary color
>  >    fcolor 153:153:153 #fill color for all polygons
>  >    end # end the Country controls
>  > Here's the command to run to generate the postscript file:
>  > ps.map input=$HOME/ps_rules.txt out=$HOME/color_admin.ps --overwrite
>  > To convert the postscript to PNG I had to use ghostscript - there are
>  > other tools you can use though.
>  > gs -dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -r300 -dTextAlphaBits=4
>  > -dGraphicsAlphaBits=4 -dDEVICEWIDTHPOINTS=473 -dDEVICEHEIGHTPOINTS=276
>  > -dFIXEDMEDIA -dPSFitPage -sOutputFile=$HOME/color_admin.png -c
>  > "<</PageOffset [-34 78]>> setpagedevice" -f $HOME/color_admin.ps
>  > So the above line needs some explaining
>  > (http://www.ghostscript.com/doc/9.27/Use.htm
> <http://www.ghostscript.com/doc/9.27/Use.htm>) but in a nutshell, the
>  > parameters to play with are first the Pageoffset [x y] values. They are
>  > in points not inches ... 1/72 inch = 1 point ... remember the 1/2"
>  > margins? the -34 gives me 2 points of white space to the left edge of
>  > the map frame, the 78 I had to play with to push the map frame down to
>  > the right spot.
>  > Next is the DEVICEWIDTHPOINTS and DEVICEHEIGHTPOINTS ... again in points
>  > ... this "trims" the paper to height and width ... set something then
>  > run it and view the results. Adjust and run again until you get it
> correct.
>  > It's a royal pain but it seems to work this way. It would sure be nice
>  > to create a GRASS workspace file and just say "convert this workspace to
>  > an image" with everything all laid out nicely - like Arc does exporting
>  > their mxd map files...
>  > I hope this helps someone !
>  > Chris
>  > On Wednesday, February 10, 2021, 11:08:00 PM EST, Anna Petrášová
>  > <kratochanna at gmail.com <mailto:kratochanna at gmail.com>> wrote:
>  > On Tue, Feb 9, 2021 at 4:41 PM Chris Bartolomei <surfcjb at yahoo.com
> <mailto:surfcjb at yahoo.com>
>  > <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>> wrote:
>  >    Hi Anna - thank you for the suggestion - I tried it but alas, still
>  >    it only outputs a single vector map (layer). I can get either the
>  >    Country vector or the admin_areas vector, but not both overlaid.
>  >    Chris
>  > I realized you are using both environmental variables and d.mon, that
>  > might cause some issues, you use one or the other. So try to remove the
>  > lines starting with d.mon.
>  > Hope that helps,
>  > Anna
>  >    On Tuesday, February 9, 2021, 1:20:52 PM EST, Anna Petrášová
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>> wrote:
>  >    Hi,
>  >    On Tue, Feb 9, 2021 at 10:25 AM Chris Bartolomei via grass-user
>  >    <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> <mailto:grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>>
> wrote:
>  >        Good morning :)
>  >        I'm using GRASS 7.4.1 on a Linux cluster so I only have
>  >        command-line capability. I have two vector layers (a country
>  >        boundary polygon and part of an administrative area map - also
>  >        polygons). I am trying to automate creating a PNG file of the
>  >        admin areas overlaying the country boundary therefore all work
>  >        has to be command-line (in a bash script). I've tried this two
>  >        ways - using the d.mon start=png method and also the ps.map
>  >        method as described below. The d.mon method appears to generate
>  >        the image with only one vector map (not both) and only colors
>  >        the borders - it won't use the fill_color setting. The ps.map
>  >        method seems to work but assumes the image is on a sheet of
>  >        paper so there's a ton of extra white-space. I'd like to use
>  >        d.mon but I can use ps.map if someone could please let me know
>  >        how to export only the computational region without all the
>  >        extra 'paper' in the image. Here's my code:
>  >        g.region vector='Country'
>  >        export GRASS_RENDER_IMMEDIATE=png
>  >        export GRASS_RENDER_WIDTH=640
>  >        export GRASS_RENDER_HEIGHT=480
>  >        export GRASS_RENDER_TRANSPARENT=true
>  >        export GRASS_RENDER_TRUECOLOR=true
>  >        export GRASS_RENDER_FILE=$HOME/country_admin.png
>  >        export GRASS_RENDER_FILE_COMPRESSION=0
>  >        export GRASS_MESSAGE_FORMAT=plain
>  >        d.mon start=png
>  >        d.vect map=Country color=210:210:210 fill_color=153:153:153
>  >        display=shape type=area
>  >        d.vect map=admin_area color=153:153:153 rgb_column=area_color
>  >        d.mon stop=png
>  >        This only produces a png with the last vector listed and only
>  >        the borders are colored with the rgb_column values.
>  >    I think you are missing  GRASS_RENDER_FILE_READ=TRUE:
>  > https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>
>  >    <https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>>
>  >    Regarding rgb_column, I am not sure, didn't have time to test.
>  >    Anna
>  >        If I do this without the d.mon start/stop lines ... i.e. relying
>  >        on the GRASS_RENDER_IMMEDIATE=png only, then only one vector map
>  >        is converted to png however it DOES do the color fill properly.
>  >        With either above method the png is the correct size.
>  >        Now using ps.map (same env variable set as above):
>  >        ps.map input=$HOME/ps_rules.txt out=$HOME/country_admin.ps
>  >        --overwrite
>  >            where ps_rules.txt is:
>  >        border y
>  >            color 81:81:81
>  >            end
>  >        vareas admin_area
>  >            layer 1
>  >            color 153:153:153
>  >            end
>  >        vareas Country
>  >            color 210:210:210
>  >            end
>  >        We don't have pstopng but we do have ghostscript:
>  >        gs-dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -dTextAlphaBits=4
>  >        -dGraphicsAlphaBits=4 -r300 -sOutputFile=$HOME/country_admin.png
>  >        $HOME/country_admin.ps
>  >        This creates the correct image (color fills, etc) but has white
>  >        margins and a lot of white space below the image likeit is
>  >        printed at the top of a piece of paper.
>  >        does anyone have any idea how to create a png with multiple
>  >        vector maps overlaying each other (and not have the extra
>  >        whitespace too)?
>  >        v/r
>  >        Chris
>  >        _______________________________________________
>  >        grass-user mailing list
>  > grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
>  > https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>
>  >        <https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user>>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210217/52b4d29a/attachment-0001.html>
