[GRASS-user] stream from grass is inconsistent with streams from ArcGIS
Mira Kattwinkel kattwinkel-mira at uni-landau.de
Wed Feb 17 23:34:04 PST 2021
Dear Ming,
what function are you using to derive the streams in GRASS?
The reason is probably that GRASS and ArcGIS use different algorithms to
obtain the streams from the dem. As far as I remember (but I might be
wrong) ArcGIS uses SFD while GRASS (r.stream.extract) uses MFD (i.e.
single vs. multiple flow directions).
So, if you want to get exactly the same streams you need to find out how
ArcGIS does it and try to set the parameters in GRASS accordingly (of
possible).
Additionally, flat areas are usually difficult for all algorithms.
Best,
Mira
On 17/02/2021 16.23, ming han wrote:
> Hi Everyone
>     I just notice that streams from GRASS are inconsistent with
> streams obtained from ArcGIS sometimes, when there is a flat or low
> slope dem region such as lakes.
>     As shown in the following figure, there is a sharp turn from
> streams derived from GRASS.
>     I love GRASS and I am a GRASS user, I am asking this because the
> DEM that I am using is MERIT hydrological pre-conditioned DEM. I guess
> they are using ArcGIS.
>     I just want to get a consistent stream network with the stream
> network provided by MERIT.
>     Is there any solution for this?
> Many thanks
> Ming
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dr. Mira Kattwinkel
Quantitative Landscape Ecology
iES Landau, Institute for Environmental Sciences
University of Koblenz-Landau
Fortstraße 7
76829 Landau
Germany
Phone: + 49 6341 280-31553
Office: Building I, Room 2.02
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210218/4938153d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210218/4938153d/attachment-0001.png>
